R50/53 rough start when cold
Old Dec 17, 2018 | 08:22 AM
Slapshottr's Avatar
Slapshottr
2003 Mini Cooper S 150K miles when temps are below freezing and it hasn't been started in a few days the Mini will turn over but has a hard time staying running. You have to play with the gas pedal to keep it running. Usually stalls once or twice. After a few minutes 2-3 you can take your foot off of the gas pedal and it will idle fine no roughness. Reminds me of an old school carb not a full injected car. Any thoughts??
Old Dec 17, 2018 | 05:48 PM
Tgriffithjr's Avatar
Tgriffithjr
Welcome to the club! Similar problem here except it doesn’t have to be cold. No codes and runs great otherwise. Haven’t figured it out yet!
Old Dec 17, 2018 | 06:33 PM
Minidogger's Avatar
Minidogger
You might try cleaning the MAF sensor. Mine had bad idle when cold & cleaning MAF helped a bunch.
Old Dec 17, 2018 | 07:12 PM
Tgriffithjr
The thing is it idles great. It just doesn’t want to start if you turn the key to start immediately. I have to turn the key to on and let the fuel pump run then start. If I try to start immediately it just cranks. I think it’s fuel related but I’ve changed the pump and filter and run cleaner through the injection system. As soon as it starts it runs great. Same symptoms whether the temp is cold or hot.
Old Dec 18, 2018 | 06:03 AM
Minidogger's Avatar
Minidogger
Have you checked to see if fuel rail pressure is bleeding down when engine is off?
Old Dec 18, 2018 | 06:36 AM
Tgriffithjr
Not since before I replaced the fuel pump two months ago, which it was doing at that time. What other areas can allow the bleed off? I need to check it again. I know I have a problem with the pass side sending unit as I have been running out of gas at a quarter tank, which is a common problem. It’s so frustrating that they designed such complications into these cars that problems like this exist with only 60,000 miles on them.
Old Dec 18, 2018 | 07:01 AM
Soul Coughing's Avatar
Soul Coughing
I had similar issues when cold, and still do occasionally, but changing the fuel filter, and the fuel filter cap (it had cracked and was leaking) has helped a lot. I do let the fuel pump prime first when its really cold, and that seems to help with the car starting faster. I would say that if your car is running out of fuel at 1/4 tank, the pickup tube is not installed or situated correctly. The two may be independent of each other, but there may be a fitting not completely attached that is affecting your cold start.
Old Dec 18, 2018 | 07:12 AM
Tgriffithjr
It’s my understanding from researching the out of gas at 1/4 tank issue is that it’s usually caused by the transfer valve on the pass side sending unit/filter housing. I haven’t changed letting the tank go below 1/4 since I changed the fuel filter except for the other day when I let my son drive the car. He let it go slightly below 1/4, being ignorant if the problem, without it running out of gas. I’m wondering if I jostled something back into working again after I changed the filter. I’m going to drive it to below a 1/4 and see if it’s working again. I’ll carry a spare gallon just in case.
Old Dec 18, 2018 | 11:59 AM
SiRaDuDe's Avatar
SiRaDuDe
Sorry if this seems out of content,
I read in a previous thread that starting the R53 (maybe others too) would have some quirks of you did not wait for the startup process to complete. (wait for gas light to go from red to orange)
Ever since I waited for this I would start up much faster, before I would have to crank a while or maybe twice to get engine to run.
Maybe all it's doing is waiting for fuel pressure to come up before cranking , but it works!
Old Dec 18, 2018 | 01:36 PM
Tgriffithjr
The point is that you shouldn’t have to wait for fuel pressure to come up. The system should hold fuel pressure. I e never driven anothe fuel I jected vehicle, and that includes everything from fire trucks on down, that required waiting for fuel pressure. If that’s normal then it is a very poor design.
Old Dec 18, 2018 | 02:07 PM
Slapshottr's Avatar
Slapshottr
I did see the rough cold start sticky under stock problems. I'll have to come up with a plan as to where I am going to start. It truly is a cold weather problem below 32 degrees just strange.
thecanuck
Apr 5, 2024 02:26 PM
GoKickyFastOk
Dec 13, 2022 06:23 PM
Ted Stevenson
Apr 2, 2011 05:55 AM
sright
22
Sep 2, 2005 07:03 PM
MINItura1
Jun 16, 2005 05:34 AM
