R52 R52s Cranks but No Spark
2007 MINI Cooper S
Hello Everyone My Mini has no Spark on all 4 Spark Plugs I Connected my Power Probe and have 12V+ on all 3 cables that Connect to the Ignition Coil Plug.
I did some Research and the 2 Black Wires are supposed to be Grounds and the Red Wire goes to Fuse #2 on the Fuse Box that is on the Engine Compartment next to the ECU.
Does anyone Know what my Issue may be? Thanks in Advance
[QUOTE=Ronald Menendez;4437084]
It’s giving me a EWS Wrong Code when I Hook up the OBD2 Scanner.[
/QUOTE]
I believe that means your key is not synced with the DME so it won’t start. I could be wrong though.
/QUOTE]
Yes, it sounds like the EWS module has gone out of sync..... I had the same thing happen on my '06 R52 JCW car earlier this year, had to send it out to RPM Motorsports for repair. I had no spark and no injector pulse when cranking it over
Bryan
Bryan
Bryan
ctrlaltdl
Jan 14, 2016 07:48 AM
