R52 Frozen fuel door cover
Old Dec 6, 2018 | 06:10 AM
Mineeee's Avatar
Mineeee
I lived in Canada for 20 years and never had this happened... I went to fuel up on my first cold day in South Carolina (-5°C / 23F this morning) and damned if I cant open the flap over the gas cap! Hopefully parking it in the sun for the day will unfreeze it and I can fill up on the way home.
I figure a good dose of WD40 should clean up any water lingering in the area? Any other thoughts/suggestions?
Old Dec 6, 2018 | 06:40 AM
ThumpR52's Avatar
ThumpR52
The retractor may be broken. This is my thread below and you get an idea how to access the retractor as it has a finger pull that may get you open.
https://www.northamericanmotoring.co...r-removal.html
Old Dec 6, 2018 | 07:03 AM
Mineeee's Avatar
Mineeee
Thanks, I wasnt aware there was any "automatic gas cap lock" mentioned in the write up? I dont think Ive ever noticed that. I thought it was just a simple flap but does it somehow lock? What causes it to unlock usually?
Old Dec 6, 2018 | 08:08 AM
Yep, on the little lock part: Check it and spray some wd 40 in there. They can stick.
Old Dec 6, 2018 | 08:11 AM
Mineeee's Avatar
Mineeee
Cheers, good to know. Hopefully its just froze and will thaw out rather than having to deal with a broken actuator.
Old Dec 6, 2018 | 08:22 AM
Yep mine did this on my r52 and hit it once a year and its ok at almost 284K miles. https://www.ecstuning.com/Search/Sit...h/51257112132/
https://www.realoem.com/bmw/enUS/sho...diagId=41_1590
Its a little green rod that pops out of that hole.
Old Dec 7, 2018 | 05:17 AM
Mineeee's Avatar
Mineeee
It was just weather related Just need to get some WD40 now as I had forgotten the shippers wont let you bring anything like that with you when you move countries:(
XXLil MickXX
Cooper (non S)
Jul 19, 2013 06:53 PM
DannoCope
Dec 12, 2010 01:14 PM
OntMini
Dec 24, 2004 09:30 AM
asp
Feb 10, 2004 02:25 PM
