mini r56 adaption issue
Old Dec 4, 2018 | 08:48 AM
kucils69's Avatar
kucils69
Old Dec 4, 2018 | 08:11 PM
E34M5's Avatar
E34M5
nothing attached. did you have work done before this occurred? timing chain stretch, jump? codes?
Old Dec 4, 2018 | 08:16 PM
kucils69's Avatar
kucils69
Old Dec 4, 2018 | 10:03 PM
E34M5's Avatar
E34M5
I would make sure cam timing is correct, maybe your out a tooth, but I think that would be very hard to do, some engines wont even run if they are out 1 tooth, I am not familiar with what controls the vanos solenoid. Maybe a good place to start. I am a MB tech, and I work with a couple of ex bmw and 1 ex-mini tech, I will check to see what they say. I know MB controls their vanos solenoids through a magnetic adjuster on the front of the timing cover, Hopefully someone else will chime in,
Old Dec 5, 2018 | 12:29 PM
Yupetc's Avatar
Yupetc
Check your non-return check valve, too. Not a common problem, but easier enough and worth the effort before you go tinker with timing assembly. That valve can clog and not allow oil to go into the VANOS unit.
Xjsf28
Jan 31, 2024 04:56 PM
Notcompensating
Jul 19, 2018 04:41 PM
geofox784
Jun 14, 2017 11:31 AM
engatwork
Apr 25, 2015 10:56 PM
imncrxtc
Jul 24, 2014 06:23 AM
