R50/53 Front Aero Bumper installation question
Old Dec 2, 2018 | 10:18 PM
Ryan Hunte's Avatar
Ryan Hunte
I've just purchased a used front aero bumper and it seems the lower lip that would screw into the mounting brackets was cut off or ripped off. Will the bumper fit sturdily without the bottom being properly attached? If not, any alternatives to mounting the bottom part? Thanks.
Old Dec 3, 2018 | 08:51 AM
Did you look at the install PDF: http://www.motoringfile.com/howto/Ae...%20Bodykit.PDF
More info here also:
https://www.northamericanmotoring.co...-question.html
Old Dec 3, 2018 | 11:58 AM
Ryan Hunte's Avatar
Ryan Hunte
Yes, the lip that would would attach to the bracket is not there. It was cut off. Using the brackets would be pointless then, so I'm wondering if anybody else has a similar issue and if they're bumper is sturdy enough without the brackets.
Old Dec 4, 2018 | 10:19 AM
HaltCatchFire's Avatar
HaltCatchFire
Mine came without the brackets, although I put them back on later. They don't add much in the way of brute strength, they're actually quite flexible - my guess is they're there to keep wind vibration and flapping at the corners in check. The top and wheel arch mounts take the weight of the bumper.
Old Jan 16, 2019 | 09:55 AM
koreycon's Avatar
koreycon
Get an m7 carbon fiber splitter, it seems to reinforce the aero bumper on my mini.
https://www.ecstuning.com/b-m7-speed...53-4m7602~m7s/
Old Jan 16, 2019 | 11:09 AM
N2MINI's Avatar
N2MINI
I ran mine for years without those black plastic clips thingys as I was pretty low I just cut them off to keep them from getting ripped off and possibly tearing up the whole bottom section. I did use that center bolt though... I made my own and sold some along the way of a copy of the M7 spitter. It is bolted to that somewhat flat area you have left so while it adds some wait to the bumper it's not helping any to hold the whole thing to the car...
chilimac
Jan 30, 2008 12:43 PM
DOPAMINE
Dec 16, 2006 07:12 PM
cooldude7
May 10, 2006 04:02 PM
fdavid
Jun 24, 2005 06:54 AM
