JCW Anyone found a 17x8 that will clear the Brembos? [5x112.4, 66.5 bore, 40 mm offset]
Old Nov 25, 2018 | 04:15 AM
cmt52663's Avatar
cmt52663
Sorry for the dedicated thread, if I have missed something already here just point!
I've looked at the NM Rse05 but near as I can tell they do not go 8" wide - only 7.5".
There are numerous offerings with an 18" diameter, but that is not what I seek.
I'll be delighted if anyone can help with this puzzle.
Kind regards,
Charlie
Old Nov 25, 2018 | 06:01 AM
cmt52663's Avatar
cmt52663
I've an inquiry pending with Automobile Associates of Canton Inc regarding Braid Wheels - we shall see.
I've another inquiry pending with NM Engineering to confirm that they can not do a 17x8.
Cheers,
Charlie
Old Nov 25, 2018 | 07:59 AM
vetsvette's Avatar
vetsvette
Moderator
I believe that NM offers a 17X8 wheel for VW. One of the forum members ordered a set of them in red and NM machined the center bore to be compatible with Mini. Give NM a call and talk to Jerry.
Old Nov 25, 2018 | 08:02 AM
chrunck's Avatar
chrunck
Somewhat related question--will an 18x7.5 clear the brakes? I'm starting to do research for my wife's soon-to-be-delivered JCW Clubman on winter wheel/tire combos.
If you find 17" wheels that fit, I'd be interested in those as well. I'd rather run a smaller wheel if possible.
Old Nov 25, 2018 | 08:06 AM
vetsvette's Avatar
vetsvette
Moderator
NM's RSe05 17X7.5 et40 will clear BBK. They also have 18" that will clear the brakes.
Old Nov 25, 2018 | 09:46 AM
chrunck's Avatar
chrunck
Thanks. I was assuming 17x7.5 wouldn't fit based on the OP's desire to find a 17x8.
Do you know if 17x7 would clear the brakes? There's a set of Paceman wheels on Craigslist for $220 that would be a steal. I have these same wheels on my Countryman. Maybe I'll wait and try my wheels on the Clubman once it gets here, though that will probably be another 3 weeks.
edit: wait, it looks like the 3rd gen bolt pattern is 5x112 while my countryman is 5x120. Rats.
Old Nov 25, 2018 | 01:35 PM
cmt52663's Avatar
cmt52663
Thank you. I will pursue my inquiries.
Cheers,
Charlie
Old Nov 26, 2018 | 12:18 PM
cmt52663's Avatar
cmt52663
And the winner is (with thanks to vetsvette) Jerry at NM Engineering, partnered with Paul at SupremePower who source the NM RSe05, and do the precision machining required to adapt it to my car.
Of course the proof of the pudding is in the eating, so it will be a week or more before I break out the bubbly.
Do stand by...
Cheers,
Charlie
Contact info should anyone else be this daft...
Paul GiontaSUPREMEPOWER 1562 Kimberly AveFullerton CA 92831 ExperiencePerformanceCall or Text: 914-243-1993Email: Paul@supremepower.com
Old Dec 17, 2018 | 03:47 AM
cmt52663's Avatar
cmt52663
Test fit this week. Will fit all four and go over the clearances carefully. Fingers crossed.
40 pounds total (17 wheel + 23 tire)...
Cheers,
Charlie
Old Dec 19, 2018 | 03:49 PM
elsnaibs's Avatar
elsnaibs
I have two sets of 17x7.5 that fit.Team Dynamics Pro Race 1.2, 17x7.5 +45
Sparco Podio, same setup. Both fit over the Brembos no problem.
Attached Thumbnails Anyone found a 17x8 that will clear the Brembos? [5x112.4, 66.5 bore, 40 mm offset]-img_20170618_192512-01.jpeg   Anyone found a 17x8 that will clear the Brembos? [5x112.4, 66.5 bore, 40 mm offset]-sparco1.jpg
Old Dec 19, 2018 | 05:53 PM
dpcompt's Avatar
dpcompt
JCW fit
Do those wheel sets fit without spacers?
Old Dec 19, 2018 | 10:47 PM
elsnaibs's Avatar
elsnaibs
They fit perfectly, no spacers and no rubbing
Old Dec 20, 2018 | 10:22 AM
cmt52663's Avatar
cmt52663
We'll see if mine will also fit tomorrow. I've asked the Pit Crew at Mini of Peabody to do a full trial install and check all clearances.
Fingers crossed - I'd hate to ship them back to the left coast again...
Cheers,
Charlie
Old Dec 21, 2018 | 01:29 PM
cmt52663's Avatar
cmt52663
17x8 NM Engineering RSe05, plus machining, is a game changer
My thanks to NM Engineering (RSe05 wheels), Supreme Engineering (Custom machining of center bores, and assembly), and of course Bridgestone for the RE71 tires. We're good to go for 2019. This is certified by the Mini of Peabody Pit Crew. Joel Decoff Crew Chief.
They fit,
Old Dec 21, 2018 | 01:44 PM
Wow thats close. Talk about tucked.
Old Dec 21, 2018 | 04:01 PM
cmt52663's Avatar
cmt52663
The pictures are inadequate, as the wheel has more clearance over the calipers than the stock one does, and the same rim & tire to strut clearance (which is about 3mm).
Not too close actually.
I am so pleased, as the car is traction limited and has very low gearing, and this solution will help both of these concerns.
Cheers,
Charlie
Old Jan 3, 2019 | 05:50 AM
Carrera2RS's Avatar
Carrera2RS
I have a 2017 JCW Challenge and the wheels look quite inset (i believe they are 7.5x17 et52) I will be experimenting with spacers soon and expect to run 10-12mm spacers. Following I am interested in some lightweight 17x8 alternatives, possibly OZ HLT or Braid, TWS or Rays
The tyres they come with are MPSC2s 215/45/17
I do really like the et40 17x8 Braid FullRace GT shown in another thread
Old Jan 3, 2019 | 05:52 AM
Carrera2RS's Avatar
Carrera2RS
PS the suspension is Nitron R1 and I am about to have a full Geo and set cambers to -2 degrees
Old Jan 4, 2019 | 07:21 PM
dpcompt's Avatar
dpcompt
If I buy the NM wheels 17x7.5 Rse05 wheels for my '19 JCW, would I be giving up any strength or durability ( compared to my factory 18x7 wheels)?
Old Jan 4, 2019 | 07:45 PM
vetsvette's Avatar
vetsvette
Moderator
You won't be giving anything up, except for saving ~8 - 9 pounds per wheel.
Old Jan 4, 2019 | 08:16 PM
dpcompt's Avatar
dpcompt
NM wheels
Thanks.
I have been thinking about how to have a decent all-season wheel tire combo for my I/O JCW for awhile. I am probably going to go with these wheels and a Bridgestone 960as ( a runflat). My car is a daily driver( never tracked) and I am going to be do some traveling in early March.
This is my fourth MINI and the suspensions have really improved over the years. I put the Bridgestones on my last MINI, a '15S, and they rode great.
I would really like to go with Michelins, but I think I like the idea of runflats when I am out in the middle of nowhere.
Old Jan 4, 2019 | 08:25 PM
vetsvette's Avatar
vetsvette
Moderator
I don’t think you can go wrong with the RSe05 wheels. I’ve been running the 17X7.5 for more than two years. Still happy with them.
Old Jan 4, 2019 | 08:30 PM
dpcompt's Avatar
dpcompt
Nm wheels
Are those the Gunmetal color?
Old Jan 4, 2019 | 08:32 PM
vetsvette's Avatar
vetsvette
Moderator
Yes.
Old Jan 4, 2019 | 09:54 PM
dpcompt's Avatar
dpcompt
17x7.5
Yes.
What size tire are you running? 205 0r 215?
