R50/53 R50 no crank
Old Nov 22, 2018 | 06:42 PM
Bardum's Avatar
Bardum
R50 no crank
I’ve had intermittent no cranking issues. I’ve already replaced the clutch safety switch, checked the alternator, swapped the starter relay and have also installed a new ignition switch. The car will not bump start, even through I hear the fuel pump going. The starter solenoid was checked and is working. I’m thinking the immobilized might not be working right and have already tried several keys with the same intermittent no crank results; even though all lights windows and interior chimes work.
I’ve run out of things to try and can’t trust this car to restart after shutting off.
Any help or suggestions would be awesome. I’m new to the mini community, however I’ve been working on cars casually for over 25 years i’d rather bypass the immobilizer over taking the car to the stealership.
Old Nov 22, 2018 | 07:11 PM
cooper48's Avatar
cooper48
X
Old Feb 19, 2020 | 06:32 AM
Fabio Capria's Avatar
Fabio Capria
Hi Bardum, exactly same as you, did you solved it? Thanks
Old Feb 19, 2020 | 06:35 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Have you checked your main grounds ? Is the power cable coming off the battery good ? Just a thought ...
Old Feb 19, 2020 | 06:52 AM
Bardum's Avatar
Bardum
yes, I did end of solving this problem by getting the Immobilizer board replaced and programmed by a local shop. The security system was not seeing the key sensors, which caused the car to not fire injectors or starter.
ChrisOhle
May 18, 2019 02:13 PM
dieseldogpi
Dec 31, 2018 06:37 AM
Bardum
Dec 17, 2018 09:11 AM
tgfh
Cooper (non S)
May 19, 2012 02:23 PM
Lolo
Feb 12, 2003 09:57 AM
