R52 (NEW OWNER NEED HELP)08 mini S engine heating and coolant temp
Old Nov 22, 2018 | 09:34 AM
bertstert973's Avatar
bertstert973
so i bought a mini with 167k on it. decent condition. needs rear struts and the normal maintenance and problems wit the coolant temp sign poppin up blowing cold air so i figured stuck thermostat. put coolant in it. same thing happend. found out the bleeder screw was loose. but i let my car warm up today and it started showing a engine over heating sign. then i gave it some gas and a cloud of smoke came out the exhaust smelling of oil. shut it off and let it cool. drove and had a light come back on. pulled over and bled the coolant. and it started working again. im lost as to wht the core problem is. and im guessing the thermostat is just gettin stuck now and then. SIDE NOTE: i came from a 92 Mitsubishi mighty max to this so im not used to the bells and whistles of these cars. i do love em tho. i def need the help and will need def need more help in the future. i hope this car lasts as long as possible. i see why ppl love them so much :) i appreciate the help too
Old Nov 22, 2018 | 12:45 PM
A383Wing's Avatar
A383Wing
Sounds more like a blown head gasket to me with the smoke coming out the tail pipe.....
Easiest way to test is to fill the cooling system, run engine for a little bit, shut down engine, remove spark plugs, get a cooling system pressure tester and pressurize the cooling system, if the pressure keeps falling, after a few times of pumping up the system, then while the spark plugs are out, have someone crank over the engine and see if any water comes out of any spark plug hole...if it does, you found your problem......either blown head gasket or possibly a cracked cylinder head
Bryan
Old Nov 24, 2018 | 06:39 AM
Tgriffithjr's Avatar
Tgriffithjr
If it’s white smoke that dissipates quickly then it’s steam. Intake manifolds can also develop coolant leaks which will leak into the cylinder when the engine is off and then burn into steam when you start up causing that puff of steam out the tailpipe.
Yoshiboy
Dec 29, 2016 05:57 PM
Trizzz
Jul 16, 2013 06:08 AM
minimike21
Mar 18, 2013 10:29 PM
Boris
Jul 9, 2004 10:33 PM
