Turbo leaking coolant
Old Nov 1, 2018 | 10:35 AM
MiniNova's Avatar
MiniNova
Hello,
I'm having a hard time finding the seals that go underneath these two turbo screws on my 2008 Cooper S. It is leaking coolant from underneath the screws.
Has anyone replaced these seals and know where two buy them or how to search for them?
Thanks!
Old Nov 1, 2018 | 11:08 AM
Yupetc's Avatar
Yupetc
Look up 07119963201 in ECS or Pelican Parts. In ECStuning, their part number is 07119963201
Old Nov 1, 2018 | 12:21 PM
MiniNova's Avatar
MiniNova
I actually bought 07119963201 at MINI dealer, but they don't fit, 07119963201 are for the coolant line, these other gaskets go on the screws on the other side of the turbo.
Old Nov 1, 2018 | 01:33 PM
Yupetc's Avatar
Yupetc
Oh yeah, forgive me for not seeing what you're pointing at. I thought you were referring t the cooling lines' copper washer.
On your issue I looked on Realoem and couldn't find a diagram that has that piece located. I think your next best move is probably to contact someone at JMTC Performance to see if those folks may be able to help. They are the turbo specialists especially with our K03 turbos. Good luck.
Old Nov 1, 2018 | 01:47 PM
MiniNova's Avatar
MiniNova
No problem mate, thanks for the info, I'll be contacting them. I'll update this post in case someone else needs the info later on.
Thanks again!
Old Nov 2, 2018 | 08:00 AM
Yupetc's Avatar
Yupetc
By looking directly at it, I'm wondering if our oil pan drain plug washer can be a fit for this. Just throwing it out there.
Old Nov 2, 2018 | 11:33 AM
oldbrokenwind's Avatar
oldbrokenwind
Maybe try to unscrew them, add some thread sealant, and screw them back in? Might even find an o-ring you can replace. Might stop or slow down the leak 'til you find the correct fix.
All this is guess-work --- I've never had my OEM turbo apart in this area.
Old Nov 2, 2018 | 11:46 AM
MrGrumpy's Avatar
MrGrumpy
Yeah, I’m not sure about that, that’s a new one for me, but as stated above, try contacting Arric at JMTC thats where I got my turbo from, good dudes.
Old Nov 2, 2018 | 01:45 PM
MiniNova's Avatar
MiniNova
Off topic but related to the turbo, did you upgrade your turbo? or just replaced with same size?
I have reached out to them with the leak question.
Old Mar 5, 2019 | 06:41 PM
Grip Grip's Avatar
Grip Grip
I think the turbo on my R60 is leaking from the same spot. What a major PITA.
mplatt911
Apr 3, 2009 10:57 AM
NC-17_Mini
Nov 18, 2007 11:50 AM
chud98
Oct 31, 2006 12:46 PM
azuul
Dec 30, 2005 04:59 AM
XAlfa
Nov 30, 2004 03:19 PM
