Temperature Warning & No Heat
Old Oct 13, 2018 | 08:00 AM
jasonl's Avatar
jasonl
Question for the mini tinkerers...2012 Mini Cooper Clubman
A couple of times now my engine temp light has come on 'yellow' but gone off shortly after. Also, not sure it's related, but my heat is not working in the cabin of the car all of a sudden...irony, my warranty expired on Oct 01. Thoughts?
Thanks,
Jason
Old Oct 13, 2018 | 10:05 AM
ashchuckton's Avatar
ashchuckton
How is your coolant level? Sounds like you may have an air bubble moving through the system. Better check this out & remedy before you cook the engine.
Old Oct 13, 2018 | 12:23 PM
Capt_bj's Avatar
Capt_bj
spot on recommendation
no coolant to the heat system = no heat. Why no coolant getting there????
Could be as simple as level has gotten LOW over time .... OR you could have a leak
Old Oct 14, 2018 | 12:45 AM
MrGrumpy's Avatar
MrGrumpy
The posts above me pretty much covered it. Sounds like it could be air in the system. You can try bleeding it. There is a bleeder screw on top of the thermostat housing. Or it could possibly need a new thermostat. But check for air first. There are some good diy’s for how to bleed the system on this site, and online and YouTube.
Old Oct 14, 2018 | 01:21 PM
jasonl's Avatar
jasonl
My coolant was severely low, I topped up and everything 'seems' fine currently. Don't seem to be getting the heat I should in the cabin, but I may be imagining that.
Old Oct 15, 2018 | 06:34 PM
MrGrumpy's Avatar
MrGrumpy
It should be making heat. If it was really low, there very well may be some air trapped in there that needs to be bled out.
Old Oct 15, 2018 | 06:41 PM
jasonl's Avatar
jasonl
Is that something I can do myself...or do I need to have someone do that for me...I'm reasonably handy but anything major I'd rather have done right.
Old Oct 22, 2018 | 07:14 PM
minidd99's Avatar
minidd99
Just keep adding coolant to the reservoir until it doesn't go down anymore after running the car up to temperature. You may have to fill up the reservoir a number of times until the air bubble works itself out. Also have the heat on max in the car. If it keeps going down you have a leak some where.
CALLE5
Jun 12, 2018 10:25 AM
Eleo
Apr 24, 2013 05:51 AM
rwkeating
Oct 30, 2007 09:59 PM
Larry Clemens
Dec 15, 2006 06:57 AM
MyPocketRocket
Off-Topic :: Autos
21
Jan 3, 2006 03:57 AM
