No start r56
Old Oct 6, 2018 | 07:06 PM
Misses9098's Avatar
Misses9098
No start r56
Hi there! I’m having some issues with my mini. It’s a r56 non s. The head gasket blew a while back which was fixed and working fine to our knowledge. Still wouldn’t start. We brought a mobile mechanic out to do a diagnostic and discovered that some of the hydraulic lifters (2 intake, 1 exhaust) were spewing oil, so we changed those and still a no start. My boyfriend has been working on the car for several months now and after every problem it’s a no start but it’s not something I can afford to tow to a mini dealer and get fixed. We think we need a leak down tester but can’t find any nearby as well. This is my Mini dream car and I would hate to sell it and not be able to get another for so long. Any and all help would be appreciated, and I can give more info when needed.
Old Oct 6, 2018 | 07:14 PM
MrGrumpy's Avatar
MrGrumpy
So it blew a head gasket. Did it run after the head gasket was fixed? Or has it not started since? Was it running before that? And finally, are you getting any trouble codes? Or do you have a way to scan it?
Old Oct 6, 2018 | 09:07 PM
Misses9098's Avatar
Misses9098
it didn’t run after the head gasket was fixed, it developed a fuel leak which was fixed with new seals. The timing was redone to bring it back to normal, just to be safe. It hasn’t ran since it initially broke down and after we swapped out the hydraulic lifters we expected it to work but nothing. We’re thinking the battery is affecting it so we took it to be charged, and it dropped 2 camshaft codes after we realized the battery wasn’t charged up well enough. Which, the battery is at autozone charging right now.
Old Oct 8, 2018 | 05:35 AM
MiniToBe's Avatar
MiniToBe
Could you confirm how the timing was done?
are all sensors connected and tight?
what year is the car and how many miles on the car?
Old Oct 9, 2018 | 03:06 PM
Misses9098's Avatar
Misses9098
the car is a 2007 Mini Cooper base model, 211k miles. The sensors are all connected and tight. Timing was done by putting a pin into the fly wheel to hold in place, the cams were positioned by hand and then tightened down. The chain was stretched from the crank over the top of the cams and slack was removed with the tensioner bolt.
Old Oct 10, 2018 | 07:13 AM
MiniToBe's Avatar
MiniToBe
did you check the ground strap on the motor mount? did you check the small green wire connected to one of the valve cover bolts?
when you say the cams, were done by hand, how did you position them?
Old Oct 20, 2018 | 05:32 PM
outtaluck's Avatar
outtaluck
My 02 did that,....then the other day my 07 did it.....after hrs of grumbling I thought..could it be ? and yes it was the saFETY SWITCH ON THE CLUTCH...Ooops solenoid falls off easily, I was amazed this had not been addres ed by Mini ..stick it back on and run a zip tie around
Hope that helps
Sorry in my haste I assumed u had a no starter motor issue
Old Oct 20, 2018 | 11:42 PM
Scudder44's Avatar
Scudder44
If you have not already done so, watch this and if you missed out any steps, take it to pieces and start again. If your timing chain had jumped off the cams or guides were broken, you may have bent valves, hence the leak/compression test requirement.
NCapurata
Apr 1, 2019 07:54 PM
ericmakkar
May 20, 2011 05:16 PM
fridayxiii
Sep 30, 2010 05:39 AM
minimalistic
May 8, 2009 11:20 PM
orangecrush
May 1, 2009 03:59 PM
