automatic
Old Sep 28, 2018 | 03:06 PM
jk6672's Avatar
jk6672
automatic
I've changed the oil and plugs on my son's 08 R55. I bought a transmission filter and gasket, but I don't see where to fill up the transmission nor did I find any Youtube instructional videos. Where do I fill it up, I'm not draining it until know how to fill it. lol
Old Sep 28, 2018 | 05:53 PM
Minidogger's Avatar
Minidogger
Search this site for drain & refill, several threads about it.
You drain by pulling out the plastic standpipe, which is inside drain plug on bottom of tranny.
Easiest way to refill (for me anyway) is to pump the new atf up thru the standpipe. When the excess runs out, the level is correct.
I used a cheapo suction gun, don't need expensive tools.
Old Sep 28, 2018 | 06:08 PM
jk6672's Avatar
jk6672
Are there different auto trannys installed in the R55?
Old Sep 28, 2018 | 07:56 PM
MiniToBe's Avatar
MiniToBe
This may help https://www.newtis.info/tisv2/a/en/r...l-pump/HjTwpQu & https://www.newtis.info/tisv2/a/en/r...ission/4JnYJ1n
Old Sep 29, 2018 | 08:24 AM
chrunck's Avatar
chrunck
It's the same as the R56, so I'd search for that instead. You'll get more results.
Old Oct 4, 2018 | 06:16 AM
MiniToBe's Avatar
MiniToBe
https://www.northamericanmotoring.co...ion-fluid.html
Urke
Electrical
Jan 15, 2013 06:39 PM
andrew
Oct 7, 2002 06:29 PM
drstevenj
30
Jul 11, 2002 05:52 AM
tmdobson
Jul 4, 2002 03:26 AM
