Need help to start R56 :(
Old Sep 24, 2018 | 07:40 AM
Terron's Avatar
Terron
Hi everyone. I’m so happy to be part of this community. I have small issue with car what we just buy from our neighbor. Long story short 2007 Mini Cooper S automatic transmission absolutely gorgeous inside and out won’t start. Starter spinning for 7-10 seconds and small puf from muffler. So I like ok is easy fix. Let’s check battery, gas and spark.
I Did work by myself :
1) I found out is better weak (get new installed and recharge old battery both work fine.
2) Fuel pump not working, no noise at all (replace the fuel pump and now is make noise and also pump gas I checked at the rump).
3) I Oreder wrench for the spark plugs and spark plugs (not check yet for the spark on the end of spark plug or conditions of them, I will update you guys later).
4) I check obd2 scanner not show any trouble codes. Order new obd2 WiFi scanner to check all data and storage codes if any.
My qwestion for all of you car gurus and experts , what else can be wrong if car not start? Neighbor tell me car just died to the road. My idea is bad HPFP or maybe camshaft sensor or DME? Any idea guys? Thanks for help
This is my mini
Old Sep 24, 2018 | 02:12 PM
Terron's Avatar
Terron
I scanned with obd2 and this what I get:
1) P0100
2) P1138
3) P0503
4) P0342
5) P1776
6) P1777
I guess I need to check camshaft senor or just buy new one?
Old Sep 24, 2018 | 02:59 PM
jglover's Avatar
jglover
Shot of starting fluid in air cleaner to see if it rumbles. If it rumbles then gas problem. No rumble electrical
Old Sep 24, 2018 | 03:07 PM
Terron's Avatar
Terron
Should I spray starting fluid into this pipe? It’s coming from the filter box to turbo
Old Sep 24, 2018 | 03:20 PM
jglover's Avatar
jglover
yes and not a lot
Old Sep 24, 2018 | 03:30 PM
Terron's Avatar
Terron
Looks like I need to get helper here. I try to spray couple times not much maybe 2-5 seconds and then crank car again. No difference. Only dry starter and engine tart tar tart tart. My son will come later today after his hockey game and I will try to spray and crank starter the same time. Thanks for the help. I keep you guys posted.
Old Sep 25, 2018 | 12:28 PM
Terron's Avatar
Terron
Hi everyone. I spray car starter strait to the turbo and zero effect. Nothing happen, just starter spinning let’s it. Check spark plugs and they make sparks but condition is really bad. Any ideas what else I can check ? Thanks
Old Sep 25, 2018 | 12:29 PM
Terron's Avatar
Terron
Old Sep 25, 2018 | 12:30 PM
Terron's Avatar
Terron
I order new spark plugs and camshaft sensor.
Old Sep 26, 2018 | 04:03 AM
MiniToBe's Avatar
MiniToBe
Did you do a compression check? Take the valve cover and take a look at the chain and everything inside. Spin the engine by hand and check the timing. Newtis.info is an excellent source to use.
Old Sep 26, 2018 | 08:51 AM
Terron's Avatar
Terron
I in Manassas VA, I will install new spark plugs and camshaft sensor tomorrow. I will try to start if not I take a park valve cover and also check compression. I keep you posted guys. Thanks
Old Sep 28, 2018 | 10:16 AM
Terron's Avatar
Terron
Hi everyone. Today I installed new spark plugs $70 for 4 :( and new camshaft sensor . Nothing change:( only car now every 5-7 seconds car puf puf from muffler. I’m absolutely lost. For tomorrow planing to do a compression test . Any idea what else I can check .
I check sparks, fuel, fuses all is fine but car won’t start. I feel like is almost there but no. I sprey starting fluted strait in the turbo and nothing happen . Any idea guys. Thanks
Old Sep 28, 2018 | 10:24 AM
Terron's Avatar
Terron
Just read scanner p1776 and P1777
Old Sep 28, 2018 | 10:50 AM
Terron's Avatar
Terron
Old Sep 28, 2018 | 11:06 AM
Terron's Avatar
Terron
Pull out new spark plugs they all wet from gasoline?
Old Sep 28, 2018 | 11:30 AM
Terron's Avatar
Terron
I also find some gas inside of the cylinders . I take it out looks like mix gas in black color.
Old Sep 28, 2018 | 11:55 AM
MiniToBe's Avatar
MiniToBe
if the cylinders are flooded with gas, did you check the timing by the way? spin the engine by hand clockwise until you see the letting on the camshafts in the middle...put some straws in the cylinders and they all have to be same height.
Old Sep 28, 2018 | 12:23 PM
Terron's Avatar
Terron
Old Sep 28, 2018 | 12:25 PM
Terron's Avatar
Terron
Ok guys. I open Valve cover gasket and plastics pieces everywhere. Looks like on top part of the engine is gone and shredded to the chain . What I’m looking here ?
Old Sep 28, 2018 | 12:26 PM
MiniToBe's Avatar
MiniToBe
well well well....a very familiar site...you might be lucky and dont have to do a valve job. but it is time to clean, replace, reset, install, and fire it up.
Old Sep 28, 2018 | 12:31 PM
Terron's Avatar
Terron
Chain is jump out of the camshaft .
Old Sep 28, 2018 | 12:33 PM
Yupetc's Avatar
Yupetc
Timing chain slipped off the intake sproket gear? This is the first time I've seen it. My previous 3 timing job experiences were all due to the top guide broken off, leaving pieces for me to find down below. If I were in your shoes, at this point, doing a timing chain job is a blind next step because you should have your valves checked first. It's probably best move to just pull the heads and have it leak down tested. Mean while, go hunt for the broken pieces and see if you can puzzle every part back together. I wouldn't close the valve cover without having that peace of mind that everything is in right order.
Old Sep 28, 2018 | 12:42 PM
MiniToBe's Avatar
MiniToBe
I have to disagree with you...it is FREE to try and put the chain back on the sprocket and rest the timing. Few years back, I bought a 2010 Clubman S with the same exact thing. I bought the upper rail and reset the timing...fired right up with no issues. it was my best turn around At any rate, I suggest resetting the timing and trying...there isnt going to be more harm than what it has been. fixing isnt just tearing apart the replacing. stop and think and verify before you waste money on something didnt need to be done.
Old Sep 28, 2018 | 01:07 PM
Mark Supinski's Avatar
Mark Supinski
The OP mentions 'plastic pieces everywhere' -- does that mean a chain guide has failed as part of the carnage & needs to be replaced? Since these are interference engines & we know the failure happened at highway speed, I'm wondering why anyone would think a valve job is not going to be needed?
Terron, I'm near you in Woodbridge. My R57 is down with misfires that I'm trying to diagnose, but if you need a hand getting the chain reinstall I could spend a few hours wrenching with you.
Old Sep 28, 2018 | 01:25 PM
Terron's Avatar
Terron
Guys I really appreciate your help in this project
My idea to get chain back on track and see if the valves damage . After that move we can decide to keep the engine or repair or maybe buy used. Mark if you have time let me know when . I don’t have any tools for the timing lock or any thing like this. I can order if needed, but if we can put chain back and try to fire up is gone be great. Let me know. I keep you posted. Thanks everyone for great support
