5E83 code, Anyone?
Old Sep 22, 2018 | 07:03 PM
Etmil35's Avatar
Etmil35
5E83 code, Anyone?
I’ve had this 5e83 code on my Mini Countryman All4 S for some time. I’ve replaced and coded the DSC pump twice. I’ve replaced the emcd clutch/final drive. I’ve checked the wheel speed sensors. I’ve had it at a specialist shop who recommended the second replacement of the DSC pump (which I did). The DSC light and 4X4! Light are on, but it appears that the stability control and AWD are working ok. Anyone have any experience with this or any suggestions?
Old Sep 24, 2018 | 07:47 AM
scf's Avatar
scf
Have you used a code reader to clear the code? To see if it pops again?
Old Sep 24, 2018 | 08:22 AM
Etmil35's Avatar
Etmil35
Yes, many times. It won’t reset because ISTA says its an active code. I
Old Sep 18, 2019 | 03:41 PM
Gabe Laughlin's Avatar
Gabe Laughlin
5E83 code
I recently had this same problem. I used a snap-on scanner and monitored the wheel speed sensors. Everything checked out ok. But under visual inspection, i found the wires broken off flush with the connector on the drivers side of the rear diff.
Etmil35
22
Apr 15, 2021 08:20 AM
MCS02
Apr 5, 2019 06:54 AM
jeeporvis97
Dec 25, 2018 07:07 PM
Etmil35
Sep 10, 2018 06:52 AM
Etmil35
Sep 2, 2018 07:38 AM
