F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 What does the Dynamic Damper Control really do?
Old Sep 21, 2018 | 11:10 AM
minikevin's Avatar
minikevin
Hey I have a 17 Clubman S All4 and I havent really messed with the dynamic damper control yet.
What does it exactly do and when should I turn it on/off? Also can you use it with sport mode? Thanks in advance!
Old Sep 24, 2018 | 06:47 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
Copied this off the web.... "BMW Dynamic Damper Control (also sometimes called Dynamic Damping Control) is a system that can change the suspension settings on the fly. Each wheel has a control unit that monitors movement 400 times per second and then adjusts the shock absorbers appropriately. The system can adjust both compression and rebound from soft to firm, adjusting to provide the best suspension for the current driving conditions, providing the most comfort and best handling possible, even on rough roads."
In other words, it makes the suspension respond to conditions faster than a conventional damper system. All of the high end cars, Ferrari included use this on their suspensions. Interestingly, GM was the 1st to bring this system out and uses it on the Cadillacs, Corvettes and Camaros and I believe license their system Ferrari.....
Old Sep 24, 2018 | 07:18 PM
Eric Avatar's Avatar
Eric Avatar
Dynamic Damper Control is set as you move from Mid to Sport mode. In Sport mode you will notice the suspension gets firmer - you start to feel road bumps a lot more. Sport mode also increases throttle response - you dont have to press the accelerator as much. Plus on my JCW, it also makes the exhaust louder (not sure about MCS and MC models).
You can customise the sport setting to not adjust the damper control, giving you a more comfortable ride (softer) with the improved throttle response and exhaust note.
But I prefer having the two distinct settings depending on my needs at that moment.
Old Sep 25, 2018 | 05:53 AM
gearhead60's Avatar
gearhead60
Dynamic Damper Control is NOT the same as the driving modes. On the MiniUSA.com it doesn't show the Dynamic Damper Control as an option for the JCW as it is not available with the Sport Suspension. The standard and S models do not have the Sport Suspension option, but have the driving modes that allow for a more sporting ride along with the option to add Dynamic Camper Control. At the time I bought mine, it was a $500 check box. Good option for the money.....
Old Sep 25, 2018 | 06:10 AM
chrunck's Avatar
chrunck
It's not an option on the lowest tier JCW, but it's included automatically on the middle and upper tiers.
acorrea
Oct 20, 2015 07:27 AM
Kimini2
Jun 6, 2014 10:51 AM
JS24
May 7, 2014 07:29 AM
etl330
Apr 9, 2014 07:40 AM
Mrdi
Apr 8, 2014 06:07 AM
