Deciphering Dealer Speak
Old Sep 13, 2018 | 02:33 PM
walter4's Avatar
walter4
I just got a new (to me) Cooper S 2011 hardtop. The previous owner kept the service records and had all service done at the dealer. I have noticed that two times in 2017 (January and June) these parts were replaced:
PKTLINES turbo lines
07-11-9-905-176 hollow bolt
18-30-7-583-746 flange nut
11-65-8-617-069 return pipe
11-65-7-534-454 oil pipe
07-11-9-963-151 gasket ring
18-30-7-574-127 flat gasket
18-30-2-756-352 clamp
18-30-7-598-251 stud bolt
11-42-8-643-758 gasket set (June only)
In both cases, the description was "oil leaking". Is this a common service that I'm going to need to perform on a regular basis? Although I'm also wondering if the gaskets were leaking all along and the January service didn't actually fix the issue?
Old Sep 13, 2018 | 03:34 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I think they are a common failure point, but twice leads me to believe it was done incorrectly first time or they only did a partial and not both at same time. Miles on car? Shouldn't be a regular thing.
Old Sep 13, 2018 | 06:23 PM
vetsvette's Avatar
vetsvette
Moderator
Sounds like the turbo oil line. If you ever need to replace it again, I would recommend the full kit from Detroit Tuned.
Old Sep 13, 2018 | 08:55 PM
Fly'n Brick's Avatar
Fly'n Brick
I'd also recommend you find a good independent BMW/MINI shop in your area and leave the warranty work for the dealership. A good indie will bust his *** to keep you happy and a returning customer.
Old Sep 14, 2018 | 04:02 AM
walter4's Avatar
walter4
Originally Posted by Minnie.the.Moocher
Miles on car?
57321 the first time and 58177 the second time.
scatpack
Aug 27, 2022 11:48 AM
jamesd
Jul 4, 2011 06:26 AM
Justmenmymini
Jun 11, 2011 07:00 AM
MarkM
18
Feb 26, 2005 07:53 AM
TiMINITim
Tires, Wheels, & Brakes
12
May 5, 2004 11:13 AM
