Drivetrain Exhaust cam sprocket sheered off
The exhaust cam sprocket sheered off. Im looking to get it repaired and while doing so wanted to add more power. I found a 10.7" cam. Does anyone know what else would need to be done to make this work or is it a direct bolt on? Is this my biggest bang for my buck or is there something else I should to while its torn apart?
When installing high-lift cams, it's advisable to check valve-to-piston clearance --- not an easy task with hydraulic lifters. There's also a "valve pre-load" check that should be done, especially if you have new valves installed --- this is another check I know little to nothing about, but failure to do it may have contributed to my last engine failure.
Finally, be sure the mechanic doing the work has Mini Cooper engine experience --- timing tools and procedure are critical, otherwise a new cam set can be considered a "bolt-on".
unless you keep your tach in the 4800-6500 RPM range while driving your car now.. a 10.7 would be a super horrible choice for making power
*high lift/duration cams move the power band to the right.. so you lose torque in lower RPM range.. where most daily driving occurs. Add to this, turbo doesnt spool until ~3k.. you will have one gutless wonder running rich around town and a screaming terror once you cross over into the cam range. I wouldnt do it unless you track the car or drag. Better ways to make 20-40hp in my opinion.
If the exh cam broke check to find out why. Did the Vacuum pump lock up? that is kinda common.
We have several used cams if you want stock that we have removed from running cars to install our performance cams
https://www.waymotorworks.com/used-e...14-engine.html
or go for our cam set after you know what all is needed for you build
https://www.waymotorworks.com/way-pe...-cams-n14.html
Cincy_jro
Oct 26, 2015 06:28 AM
Xer0 Ph0kus
Tires, Wheels, & Brakes
14
Dec 23, 2009 03:49 PM
fozworth
May 16, 2007 11:04 AM
fozworth
May 3, 2007 01:12 AM
