A/C blower operating only at low speed
Old Sep 2, 2018 | 09:05 AM
FloridaSteel's Avatar
FloridaSteel
For the past few weeks, my 2013 Mini Clubman S with Climate Control system has been intermittently only operating at a low speed. Attempting to manually increase the fan speed does nothing. There is cold air coming out of the vents, but I can't get it to blow a larger volume/faster speed. The next time you get in the car, everything works fine.
I've checked the alternator and the output is good.
I checked the cabin air filter and its in good shape.
Fuse is ok.
Suggestions?
Old Sep 9, 2018 | 09:21 PM
FloridaSteel
Checked the blower motor resistor.
was a big help at figuring out how to get the resistor out. Put the test meter on it as shown in the video and it seems to be operating properly. The fan motor still seems to be operating very randomly. I tried installing a new resistor and strangely enough the blower stopped working all together. Put the old one in and its currently operating as it should be.
This one has me stumped. The blower is completely random now. Some days it works at all speeds, some days it won't operate at a higher speed than low. Not sure what else to check...
Old Sep 10, 2018 | 04:10 AM
Qik420's Avatar
Qik420
Sounds like the lo-1-2-3-4 etc. switch is faulty.
Old May 11, 2022 | 08:12 AM
nixoals's Avatar
nixoals
Hi,
Did you find where was the problem? I have the exact same issue, only half speed. The blower motor seems to move freely. I've checked the the blower resistor with a multimeter and the voltage increase to reach a maximum at 5.2V. Even if I increase speed it stays at 5.2V.
Could it be the resistor, or the maybe the switch?
Old Jul 10, 2022 | 12:07 PM
Jentry's Avatar
Jentry
Originally Posted by nixoals
Hi,
*Following!
I also have the exact same issue. The resistor is not at fault, but what is?!?
This is an intermittent blower speed issue. Sometimes it works properly. Sometimes it blows only on low speed.
Please let me know if you find a solution.
Old Nov 21, 2022 | 03:57 AM
nixoals's Avatar
nixoals
Originally Posted by Jentry
*Following!
Found the issue!!
May be it's too late for you but It was the battery. In fact i've ignored many warnings, like the start and stop that was not working anymore (about 1 year ago 😅) but it was ok for me I always deactivate it, time to time the car didn't start correctly, and finally I had a yellow warning that said service (but the battery voltage was ok at that time), until the battery was completely dead. I changed it and now it's working correctly.
My guess is that if the voltage drop, the AC is maybe not the "priority" 😁. When I've checked the voltage through the blower motor resistor I only had between 0 to 5-6V instead of 0 to 12V for low to max position. Witch is not the default behavior of fault resistor or a dead blower motor
Hope this will help you! or maybe somone else
Old Jan 11, 2023 | 08:48 AM
hamptup's Avatar
hamptup
I'll inspect the battery but has anyone else resolve this issue?
North of 60
15
Sep 22, 2025 10:47 AM
Mini33073
Aug 18, 2019 09:34 AM
9sec240
Feb 11, 2019 12:10 PM
j103943
R55 :: Clubman Talk (2008+)
Oct 24, 2016 06:31 AM
shub
Nov 11, 2014 07:13 AM
