R57 speed sensor
Old Aug 20, 2018 | 05:52 PM
GTODave's Avatar
GTODave
R57 speed sensor
So i stripped the threads on my wife’s R57 lugs and replaced the hub since I wasn’t happy after I ran a tap thru it. Now I’m getting the abs lights on. I thought a 2009 and 2013 would be the same? I didn’t mess with the speed sensor at all. Should I have? I need to take it off and recheck everything. The code I got I should’ve written down but didn’t. It was the wheel I replaced the hub and dealt with the speed sensor. Any suggestions?
Old Aug 23, 2018 | 06:54 AM
GTODave's Avatar
GTODave
So aftermarket hubs are all the same for the 2nd gens so I doubt it’s the used hub. I took it apart again and everything seems fine. Lights are back on so I’ll get the codes later. My next question is should the reluctor(tone) ring be spinning with the bearing all the Time? I think so as that would indicate wheel speed. Mine isn’t connected to the center part that always spins with the wheel. Anyone know that answer?
aRustyPatina
Mar 14, 2018 04:07 AM
tivoselecta
Feb 13, 2016 03:51 PM
BChili
Oct 11, 2011 08:53 PM
walls
Oct 16, 2009 09:04 AM
