I would highly recommend using Redline D4 ATF. If Royal Purple says "Meets JWS-3309" spec on the bottle then go for it. However I used did the service myself and used Redline D4 ATF and noticed a huge difference right away.
thanks! I’m going to order some right now. I found out that RACING ATF will not work on electronic shift trans. So only Royal Purple’s MAX ATF if going the Royal Purple route.
