Manifold pressure too low.
Old Jul 27, 2018 | 07:27 PM
uni's Avatar
uni
2007 S R56, no mods currently installed.
Originally had a 2885 (Boost Deviation Plausibility Error) code. I replaced 2 MAP sensors for inlet and temp because there was oil on them.
That code went away after replacing those MAP sensors, but then 3 more appeared: P129E, P0107, P1255.
Kind of the same situation as this, except I wasn't replacing the turbo or dv.
I was also told by a mechanic it could be the ECU or a broken wire, however in his scenario it was a MAP sensor, which I already replaced.
How could I check the ECU or narrow this problem down further?
Old Jul 28, 2018 | 10:36 AM
uni's Avatar
uni
Most likely a non OEM sensor since a different code appeared. Will follow up once I get a new one for the manifold.
Old Aug 3, 2018 | 07:55 PM
uni's Avatar
uni
For anyone looking at this thread in the future, I was able to solve my problem by getting a real OEM sensor.
I had gone in for repair work and for some reason they replaced this sensor, it was working fine before so I really don't understand what they were up to but I'm never going back...
Also here's a link to a pretty cheap one ($40) https://www.pelicanparts.com/More_In...-7-540-508-M14
Hope this helps someone.
ozmusafir
Dec 9, 2022 01:27 AM
05 sd mcs
Jul 1, 2013 08:49 AM
chaunghian
Mar 31, 2011 09:16 AM
Phurbahl
Cooper (non S)
Nov 15, 2006 10:08 AM
