2010 cooper base model no spark in all cylinders
Old Jul 20, 2018 | 12:41 PM
jeffle's Avatar
jeffle
My wifes cooper has no spark. Everything else seems to work except the wipers. We had the car at a friends for some paint work and the battery went dead. His helper cleaned the battery cables and it wouldnt start. I went over to look at it and discovered no spark. Also found water in the cabin by the fuse box on the passenger side footwell. I Pulled the fuse box out and cleaned the white corrosion off the the fuse box connections, re-installed it and still no spark. I did a compression check and the reading were #1,40 psi,#2,150psi,#3,130psi and #4 had 150psi. The car has never given us a problem since owning it.
Old Jul 21, 2018 | 04:25 PM
MiniToBe's Avatar
MiniToBe
If the fuse box got corroded, i think it could be damaged. You can get another one from a donor car with same part number.
Old Jul 21, 2018 | 07:25 PM
jeffle's Avatar
jeffle
Would it cause no spark to all cylinders?
Old Jul 21, 2018 | 09:20 PM
MiniToBe's Avatar
MiniToBe
It would because the communication between the DME and the fuse box aren't properly established/faulty. I have a flooded CM that would start at times and other times it wouldn't it. I replaced the fuse box alonflg with other things (the water was a bit too high) and all is good.
Also, you could try checking the ground wire on the valve cover and on the engine mount bracket.
Old Jul 22, 2018 | 08:53 AM
jeffle's Avatar
jeffle
I found this one ebay. https://www.ebay.com/itm/2010-Mini-C....c100290.m3507
Old Jul 22, 2018 | 10:43 AM
MiniToBe's Avatar
MiniToBe
I have a feeling this on is from a turbo charged one. Does it match the part number?
Old Jul 22, 2018 | 10:54 AM
jeffle's Avatar
jeffle
Here’s my fuse box The numbers look the same except. the 005527506
Old Jul 22, 2018 | 10:55 AM
jeffle's Avatar
jeffle
Which is the part number?
Old Jul 22, 2018 | 11:03 AM
MiniToBe's Avatar
MiniToBe
You are correct. It is a match. Go for it or if you find a cheaper one
Old Jul 22, 2018 | 11:09 AM
jeffle's Avatar
jeffle
Cool. Thanks
Old Jul 22, 2018 | 11:10 AM
MiniToBe's Avatar
MiniToBe
Keeo us posted
Old Jul 22, 2018 | 11:15 AM
jeffle's Avatar
jeffle
Will I have to do any programing once I get it installed?
Old Jul 22, 2018 | 11:18 AM
MiniToBe's Avatar
MiniToBe
In general, it will do the work and function normally. You could program it later at anytime using Winkfp and NCS expert or ISTA/P.
Old Jul 22, 2018 | 11:37 AM
jeffle's Avatar
jeffle
Ok thanks
Old Jul 26, 2018 | 05:39 PM
jeffle's Avatar
jeffle
Well I installed the fuse box I bought off ebay. Hit the starter and she fired right up. Now I need to figure out why water got in the car.
Old Jul 26, 2018 | 05:44 PM
Shiner's Avatar
Shiner
Great news, glad that worked for you.
Old Jul 26, 2018 | 06:02 PM
MiniToBe's Avatar
MiniToBe
Good job brother
Old Jul 26, 2018 | 09:12 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Got a sunroof? check the drains, clogs resulting in water in the car is a common problem.
2005Deucei
Jan 2, 2025 11:27 AM
Keven Chagoya
Jun 22, 2017 10:15 AM
Superdave88
Jun 10, 2015 09:34 AM
jkjrb2000
Sep 8, 2010 06:47 PM
