28BD Throttle valve, closing spring check: Malfunction
Old Jun 27, 2018 | 02:44 PM
newt05452's Avatar
newt05452
Hello folks,
Just curious if anyone has experienced this issue? I just figured I'd get peoples 2 cents before buying a new throttle body. Thanks!
Old Jun 29, 2018 | 03:32 PM
newt05452's Avatar
newt05452
Update:
Problem only got worse. A MIL code finally came on and the throttle is hesitating during acceleration. I ordered a new throttle body and gasket from RockAuto. I will keep you folks posted as to how it goes.
Old Sep 3, 2018 | 04:42 PM
guspi76's Avatar
guspi76
Originally Posted by newt05452
Update:
Did this fix the problem. Having these issues right now. Thanks
Old Sep 4, 2018 | 01:33 AM
newt05452's Avatar
newt05452
Yes it did fix it. Air box had to come out. Pain to reach. Hand tight on the three mounting screws works just fine. There is a toque spec but after following it I realized as long as it’s hand tight and you don’t break the plastic you’ll be good. I don’t rember the spec. The one I ordered from rock auto is the same one as you get from Mini. Just different vendor and a third of the cost. You’ll need a torx set. Good luck
Old Jun 1, 2021 | 07:56 PM
iissac22's Avatar
iissac22
r60 and mine just went out I guess. I r
cleaned it but I think it’s electronic failure. But same code
Old Jan 30, 2024 | 08:59 AM
Just came across this post, these are the other codes it might throw 2B32, 2B31, 2B1E, 2B2B, 2B22
Also recalibrate to make sure it has not failed. We have VDO and some other options.
https://www.northamericanmotoring.co...ody-issue.html
ptkacik
Apr 26, 2018 12:19 PM
Carmichael
Aug 20, 2013 12:33 PM
mini4door
Jan 28, 2013 06:15 AM
Goodwood
Mar 14, 2008 05:35 PM
Chips-O'Toole
Oct 22, 2003 06:20 PM
