new guy! with problem
Old Jun 14, 2018 | 08:32 AM
ledgerd123's Avatar
ledgerd123
New Guy! with a problem
Hey everyone! Im a first time Mini owner and i need some help. Not sure if this is the right thread so let me know if i need to go to a different one. Just bought a 2011 countryman s all4. has 60k miles, and ive put about 500 of those on. My wife took it on a trip and when she got to the destination the engine light came on and the engine started to misfire. She got it home and i hooked up the scanner found misfires on #2 primarily. Changed the spark plugs, put good fuel in and everything cleared up. this morning she said it was acting up again. I do recall something to do with the fuel pressure on the scanner but it only had 1 ping on the codes. Any advice would be appreciated.
Old Jun 14, 2018 | 08:38 AM
StephenM's Avatar
StephenM
Welcome to the forum!
Would recommend you post this in the R60 section. More likely to get a useful response there!
Old Jun 14, 2018 | 09:36 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
What was the code for the fuel issue? Could be a High Pressure Fuel Pump, which would be covered by the extended program they put in place.
Old Jun 14, 2018 | 09:42 AM
ledgerd123's Avatar
ledgerd123
not sure now, gonna check when i get home, good to know there is an extended program. im going to move this to the R60 thread. Thank you!
Old Jun 14, 2018 | 09:55 AM
vetsvette's Avatar
vetsvette
Moderator
If it’s the same cylinder misfiring I would swap coil packs with another cylinder to see if the problem moves.
Welcome to the neighborhood.
Old Jun 14, 2018 | 10:18 AM
JABowders's Avatar
JABowders
Veteran: Army
Welcome.
+1 on swapping the Coil Pack to see if the problem moves.
Follow up with the R60 folks.
Best of luck and ...
Motor On!
Old Jun 14, 2018 | 11:07 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I am going to merge this with you post in the 1st Gear area as it is already getting some responses.
And welcome to NAM.
Old Jun 14, 2018 | 11:13 AM
ledgerd123's Avatar
ledgerd123
I appreciate it, thank you
Old Jun 14, 2018 | 11:48 AM
ke3ee's Avatar
ke3ee
At 60k it is due for both plugs and Coils
Old Jun 15, 2018 | 05:51 AM
ledgerd123's Avatar
ledgerd123
UPDATE! so i put the scanner on it last night and I had 2 engine codes. both were a low fuel pressure and 1 had a cold start addition to it. Also the wife told me ( and i also duplicated it in the drive way) when the engine starts acting up like its misfiring if you shut it of and turn it back on it goes away. Ill also add that it makes an rattling like noise from the driver side of the engine while its acting up. at first i thought maybe the A/C compressor was taking a crap but it doesn't change when i turn the A/C off.
Old Jun 15, 2018 | 06:44 AM
ke3ee's Avatar
ke3ee
Bad HPFP should be under 120k mile warranty. call a Mini dealer
Old Jun 15, 2018 | 07:56 AM
ProjectMini's Avatar
ProjectMini
Also call a MINI Mechanic in an effort to get an expert on your side.
In the bay we have two really good MINI shops. I have a trusty dealer that i triple check through my MINI mechanic.
Old Jun 20, 2018 | 04:25 PM
MrGrumpy's Avatar
MrGrumpy
Could be the HPFP. But like mentioned the first thing I would do is put in new plugs and coil packs. Since you are new, here is a tip that I had to learn the hard way, don’t buy cheap parts!!! OEM plugs and coils ONLY! If not you will probably suffer from misfires.
Definately swap the one that says is misfiring with the one next to it, then Drive it and see if the miss moved, if it did, you need a new coil, it’s that easy.
hint #2 you can buy OEM coils from Delphi, same part # as came on the car but without the “MINI” logo.....for a LOT less!
Welcome and let us know how it turns out
MRundel
Jun 19, 2018 10:28 AM
NyVetteMiniGuy
Sep 20, 2017 01:01 PM
Old Guy
Feb 26, 2011 09:02 AM
HighSchoolzMINI
15
Oct 21, 2006 10:47 AM
MiniAlex
Mar 21, 2006 08:45 AM
