2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Wheel stud conversion?
Old Jun 13, 2018 | 06:18 AM
F56-JCDub's Avatar
F56-JCDub
As I plan for aftermarket wheels, the wheels I want will require a 5mm hub centric spacer to clear the JCW calipers. Rather than try to figure out the exact longer lug bolt size to accommodate the new wheels and the additional 5mm, I am considering converting to wheel studs:
https://www.ecstuning.com/b-ecs-part...t/prf75ch5kt5/
Has anyone here converted to studs on a Mini or other car? What was your experience?
Old Jun 13, 2018 | 08:00 AM
Minibeagle's Avatar
Minibeagle
Easy peasy. I just replaced an older set with a brand new set
Here are a couple of videos that might be useful
Old Jun 13, 2018 | 08:34 AM
F56-JCDub's Avatar
F56-JCDub
Definitely will be straight-forward. What do you think of the extended studs poking out? What did you use for lug nuts?
Old Jun 13, 2018 | 09:41 AM
Minibeagle's Avatar
Minibeagle
I have absolutely no issue with the studs poking out. I like the look: I actually prefer it over the the look of lug bolts. And the wheel studs make my wheel changes (from dailies to autocross setup) so much easier.
I bought my latest kit from Motorsport Hardware. I bought the 14×1.25 to 12×1.5 kit with black conical seat nuts. I needed the 14mm to 12mm kit because I have wheels that can't accommodate 14mm studs / bolts: ADAPTER / CONVERSION STUD 14×1.25-12×1.5* 78mm Black Bullet Nose Stud Kit
The F60 uses 14×1.25 bolts / studs, so one of these sets would work for you: MINI 14X1.25 WHEEL STUD KITS
The transaction with Motorsport Hardware was great and the package was shipped quickly and profesionally. Product also appears to be top notch.
xizor
For Sale (DC Metro MINIs) (Archive)
Jul 26, 2008 06:21 PM
grodenglaive
Suspension
Apr 20, 2008 04:20 PM
racinbmw
Tires, Wheels, & Brakes
Oct 6, 2006 12:18 PM
MiniPilo
Mar 26, 2004 06:36 PM
