R52 Help identifying the Slave clutch
Old May 27, 2018 | 02:35 PM
gum's Avatar
gum
This is what is mounted on my transmission
I ordered a replacement but this is what I got, this is a plastic and the one attached to my transmission is made of metal !
Can that be interchanged or I need to order the correct one?
I’m not the original owner, so idk what they had done with this engine !
Old May 27, 2018 | 08:20 PM
gum's Avatar
gum
I was able to find the right part, it seems that my car has an r50 transmisión !
I’m wondering what type on engine this thing has. Is there any specific place besides labels to make sure what kind of beast I’m dealing with?
Old May 27, 2018 | 08:21 PM
gum's Avatar
gum
Here is my vin #Wmwrf33556tf65561
Old May 29, 2018 | 12:21 PM
SonicTheMini's Avatar
SonicTheMini
r50 is the base first gen mini cooper, r53 is the s, and r52 signifies the first gen convertible both base and s
Old May 29, 2018 | 07:04 PM
gum's Avatar
gum
What I’m confuse, my car chasis it’s 2006 but it’s transmission is a r50!
am I right? I thought I have an R52!
So can a 2006 base convertible have a r50 transmisión?
or obviously the transmission and engine got swaped out?
I need to know so I know which model I should order parts!
Old May 30, 2018 | 05:44 AM
Fastlane's Avatar
Fastlane
R50 is the designation for the non-supercharged base model hardtop with a 5 speed manual (or cvt).
R53 is for the supercharged “s” model hardtop with a 6 speed manual (or auto).
R52 only designates that the car is a cabrio/convertible. It can have either of the drivetrains above......sounds like you have a base non-supercharged with a 5speed? If that’s the case, you’d generally want to order engine/trans parts for an R50 when in doubt.
Old May 30, 2018 | 07:56 AM
gum's Avatar
gum
Thank you, yes my car it’s 5 speed non-turbo base convertible.
it seems that it has a transmission of a R50, because I ordered the slave clutch of a R52 but it’s not the same, the slave clutch on the r50 are made of metal.
i would have to return it and get the correct one.
Thanks for your time!
Old May 30, 2018 | 08:45 AM
SonicTheMini
you ordered the slave of an r53 which would fit an r52 if it had the supercharged engine. its kind of tricky to order parts for the r52, if you have a non supercharged r52 than you can select r50 when researching drivetrain parts
Old May 30, 2018 | 09:48 AM
gum's Avatar
gum
Yes endeed it’s tricky, I hope the clutch I ordered it would fit the r50. What a mess! Since I was ordering stuff for r52,🙈
i might need need to return it the clutch kit too.
Thanks for your input 👍
Old May 30, 2018 | 11:58 AM
SonicTheMini
no problem! good luck!
Ken Garchow
Feb 12, 2018 07:12 AM
mdurando
Sep 25, 2016 09:26 PM
edprok
Jun 8, 2016 02:51 PM
edprok
Jun 8, 2016 10:50 AM
dwm
Nov 21, 2006 12:07 AM
