R52 Help identifying the Slave clutch
Old 05-27-2018, 02:35 PM
gum's Avatar
gum
gum is offline
This is what is mounted on my transmission
I ordered a replacement but this is what I got, this is a plastic and the one attached to my transmission is made of metal !
Can that be interchanged or I need to order the correct one?
I’m not the original owner, so idk what they had done with this engine !
Old 05-27-2018, 08:20 PM
gum's Avatar
gum
gum is offline
I was able to find the right part, it seems that my car has an r50 transmisión !
I’m wondering what type on engine this thing has. Is there any specific place besides labels to make sure what kind of beast I’m dealing with?
Old 05-27-2018, 08:21 PM
gum's Avatar
gum
gum is offline
Here is my vin #Wmwrf33556tf65561
Old 05-29-2018, 12:21 PM
SonicTheMini's Avatar
SonicTheMini
SonicTheMini is offline
r50 is the base first gen mini cooper, r53 is the s, and r52 signifies the first gen convertible both base and s
Old 05-29-2018, 07:04 PM
gum's Avatar
gum
gum is offline
What I’m confuse, my car chasis it’s 2006 but it’s transmission is a r50!
am I right? I thought I have an R52!
So can a 2006 base convertible have a r50 transmisión?
or obviously the transmission and engine got swaped out?
I need to know so I know which model I should order parts!
Old 05-30-2018, 05:44 AM
Fastlane's Avatar
Fastlane
Fastlane is offline
R50 is the designation for the non-supercharged base model hardtop with a 5 speed manual (or cvt).
R53 is for the supercharged “s” model hardtop with a 6 speed manual (or auto).
R52 only designates that the car is a cabrio/convertible. It can have either of the drivetrains above......sounds like you have a base non-supercharged with a 5speed? If that’s the case, you’d generally want to order engine/trans parts for an R50 when in doubt.
gum (05-30-2018)
Old 05-30-2018, 07:56 AM
gum's Avatar
gum
gum is offline
Thank you, yes my car it’s 5 speed non-turbo base convertible.
it seems that it has a transmission of a R50, because I ordered the slave clutch of a R52 but it’s not the same, the slave clutch on the r50 are made of metal.
i would have to return it and get the correct one.
Thanks for your time!
Old 05-30-2018, 08:45 AM
SonicTheMini
you ordered the slave of an r53 which would fit an r52 if it had the supercharged engine. its kind of tricky to order parts for the r52, if you have a non supercharged r52 than you can select r50 when researching drivetrain parts
gum (05-30-2018)
Old 05-30-2018, 09:48 AM
gum's Avatar
gum
gum is offline
Yes endeed it’s tricky, I hope the clutch I ordered it would fit the r50. What a mess! Since I was ordering stuff for r52,🙈
i might need need to return it the clutch kit too.
Thanks for your input 👍
Old 05-30-2018, 11:58 AM
SonicTheMini
no problem! good luck!
Ken Garchow
02-12-2018 07:12 AM
mdurando
09-25-2016 09:26 PM
edprok
06-08-2016 02:51 PM
edprok
06-08-2016 10:50 AM
dwm
11-21-2006 12:07 AM
Quick Reply: R52 Help identifying the Slave clutch
