R60 Is your Auto trans jerky?
Old May 23, 2018 | 07:51 AM
snwmble's Avatar
snwmble
Question Is your Auto trans jerky?
I bought an automatic '15 CM couple months ago CPO. I've always noticed since driving this car that the transmission always lurched between gears and isn't smooth. I took this as being normal, but while the car is still under warranty, I had to ask "is it normal?"
It is even more pronounced in sport mode which is to be expected, but even in regular mode the tranny doesn't transition into other gears that smoothly. Sometimes I feel like it hunts for the proper gear to be in as well.
Old May 23, 2018 | 09:20 AM
Dave.O's Avatar
Dave.O
I would take it in and have it checked out if it is still under warranty.
Old May 23, 2018 | 09:47 AM
snwmble's Avatar
snwmble
Thanks, I'm gonna make an appointment......in the meantime I just ordered the NM torque arm insert. I'll prob install after the dealer visit with hopes it helps!
Old May 28, 2018 | 01:33 PM
kredlin01's Avatar
kredlin01
I have also experienced this with both my Countryman and a 08 Cooper s I had. I noticed that if I put bottle of fuel injector cleaner in and then beat the crap out of it it seems to run better after that.
Old May 30, 2018 | 12:12 PM
MiniToBe's Avatar
MiniToBe
it all depends on mileage and how it was driven...the car "learns" your driving habits and adjusts accordingly. if the car has high mileage, then an ATF is overdue.
Old Jun 4, 2018 | 09:43 AM
snwmble's Avatar
snwmble
installed the NM poly inserts over the weekend, and man did that little thing address the lurching issue I had.
Downshifts are MUCH smoother than before. Well worth the money!
sparkyj
Nov 23, 2015 04:39 AM
torpeau
Jan 30, 2015 11:29 PM
wwwest
Jun 25, 2014 12:41 PM
GSequoia
Sep 23, 2013 05:33 PM
solarain
Jun 15, 2010 04:44 PM
