F55/F56 Auto Trans -- 1st gear shifts jerky?
Old Jan 27, 2015 | 06:35 PM
torpeau's Avatar
torpeau
Seems like when I go around a corner, I'm usually at a speed where the transmission downshifts to 1st with a jerk. Upshifts and downshifts involving 1st gear are the least smooth. Probably because 1st is super low and not a close ratio to 2nd. The jerkiness is normal -- right?
Old Jan 28, 2015 | 06:51 AM
kurosh's Avatar
kurosh
mine feels jerky when there is traffic and i am going 10 mph or so and it downshifts from 2nd to 1st
Old Jan 28, 2015 | 11:50 AM
anotherminiinthegarage's Avatar
Have not noticed any issues with ours
Old Jan 28, 2015 | 01:48 PM
Landspeeder's Avatar
Landspeeder
Many early 2014 'Justas' with automatics experienced ragged/jerky downshifts as well as cold engine drivability issues. Did not seem to be wide spread and was cured when the dealer was made aware of the situation. The fix was an up-grade to the software. Because my car was one of the first that the dealer serviced for these issues, the car was kept overnight to measure the effectiveness of the cold engine issues (gave me loaner Countryman). The result was immediate - no cold driving issues and the jerkiness of downshifts disappeared. However I can still induce the downshift issue if I keep even a little pressure on the gas pedal when coming to a stop.
Due to some knee and ankle problems I brake with my left foot. With all of the electronic controls and across-connections it is possible to confuse the car with a lazy right foot ( car: ok pal, do you want to stop, go, or what?) In addition, almost any car with an auto trans can be confused as to weather to shift up or down by varying pressure on the gas when maneuvering. Operating the trans in 'auto-stick' mode would likely eliminate this.
Old Jan 28, 2015 | 03:27 PM
TheBigNewt's Avatar
TheBigNewt
Mine downshifts to first right before I come to a stop only and in the Sport mode (I always use this) but it's not obnoxious or anything. It shifts out of first really quickly, more quickly than I used to with the manual.
Old Jan 30, 2015 | 11:29 PM
hammerhands's Avatar
hammerhands
I get a hesitation when I slow down for a moderately tight turn and then hit the gas a little sharply. It feels like a stall for a fraction of a second, then, whoosh, the throttle responds, the car gets in gear and the power is back.
09R56
Nov 16, 2022 10:49 AM
Ryephile
Aug 25, 2015 06:51 AM
Norton70
R57 :: Cabrio Talk (2009+)
Aug 18, 2015 04:29 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
