Window fogging!!!
Old Nov 4, 2004 | 05:51 PM
TheBlackBrian's Avatar
TheBlackBrian
Window fogging!!!
OK. The title basically tells you what this is about, but I have a bad window fogging problem. It just started to get into the 50's and 40's here (Houston area blah!), and I need to use my heater sometimes. This is the first winter with my MCS so this is new to me. The problem is I cant keep my heat on for more than a couple seconds or I will basically go blind. Is there some trick, or button that couteracts this? Ive had to switch the A/C on towards the windows to get ride of it, and thats not fun in the morning. PLEASE HELP ME!
Old Nov 4, 2004 | 05:55 PM
rioman's Avatar
rioman
A/c
A/C is air that is conditioned hot or cold. Try running the a/c with the heat......
Old Nov 4, 2004 | 05:59 PM
RaiderZA's Avatar
RaiderZA
Yes!! Keep your compressor on with the heat will defog the windscreen. The compressor will remove the humidity from the air.
This is common in all cars for effecient defogging.
Old Nov 4, 2004 | 06:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Check this out-
http://www.htby.org/archives/000212.html
clean the inside windows well and
run the AC with the defroster.
If you can open the windows a bit to let fresh air in and moisture filled air out that might also help but not if it gets too cold to drive that way.
Old Nov 4, 2004 | 06:31 PM
VRBeauty's Avatar
VRBeauty
Do you have your recirculation on? If I accidentally leave my MINI's air circulation set on "recirc", the windows will eventually fog up even without the heat on--the car's seals are that tight. Once the fogging starts, it goes total very quickly. This is especially true if I have a passenger and we're in the midst of a heated conversation!
Old Nov 4, 2004 | 07:04 PM
TheBlackBrian
O! Probably should have tried that before I wasted this thread space... Hopefully that will work. Will see in the morning, and thanks for answering so quickly.
Old Nov 4, 2004 | 09:01 PM
Ryephile's Avatar
Ryephile
uhhh, defroster?
Old Nov 4, 2004 | 10:28 PM
Rawhyde's Avatar
Rawhyde
If you're also smelling a funny sweet smell, then the heater core may be leaking. That causes the windows to fog up pretty bad. Hopefully, you just have it in recird mode.
Rawhyde
Old Nov 5, 2004 | 08:24 AM
Cooperb!'s Avatar
Cooperb!
I bet it's a cleaning issue!
Any residue on the inside of the screen causes extra fogging, so clean well to avoid the problem.
For best results, use a decent glass cleaner and a microfiber cloth.
I'd suggest Autoglym Glass Polish
It's better than anything else out there!
Chris.
Old Nov 5, 2004 | 08:34 AM
mini giant's Avatar
mini giant
i know this is a little off topic, but i noticed that when i click on my rear defroster, it automatically turns off after a certain amount of time. is this normal?
Old Nov 5, 2004 | 08:44 AM
RaiderZA's Avatar
RaiderZA
yes. Most rear defoggers have a timed function.
Old Nov 5, 2004 | 08:45 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Yes.
Old Nov 5, 2004 | 11:03 AM
kenchan's Avatar
kenchan
Very true. I use an ammonia-D based windex foam since I don't have
window tint.
When I use heat, I don't need to use the AC unless it is raining outside.
I turn the HVAC in the non-recirculation mode and that's that.
A few weeks ago I was in my other car and my car fogged up real
badly...I tried everything, AC, defroster, the non-recirculation,
etc....nothing worked.
Then I noticed that the fogging was on the outside of the window.
Looked at my climate control's temp and it was set at 60F. hahaha.
Brought it up to 70F and everything was good from there.
Old Nov 5, 2004 | 05:58 PM
lotsie's Avatar
lotsie
My MC clears the windows of fog and ice faster than any car I have owned.
Even at -alot temps,I can start the car,get out and sweep off the snow,not scrap the ice,and by the time I work around the car the windows are clearing,the rear defroster has done it's job,and a squirt of heated window washer clears the windshield.
Peking Duck
Jan 19, 2021 03:17 AM
RobbyD
Jan 29, 2019 01:22 PM
MiniSMan
Sep 29, 2015 06:38 PM
krohm
Sep 28, 2015 12:16 PM
rt808
Sep 25, 2015 01:59 PM
