R56 transmission leak?
Old May 6, 2018 | 09:20 PM
Doc McCoy's Avatar
Doc McCoy
transmission leak?
I have a 2013 mini cooper S hardtop. The other day I found a huge amount of fluid in front under the car in the garage. In the process of trying to locate the source I called the mini dealer in Charlotte who told me that my transmission was sealed from the factory and I could not check the level. Long story short in looking underneath while on the lift there is a hole in the bottom off what I believe is the transmission where I can clearly see a gear. The hole doesn't appear to have threads. Is this some kind of plug that has come on and drained the fluid? If so can this be fixed or am I looking at a new transmission. What puzzles me is there are all kinds of youtube stuff showing changing fluid in a 2013. I will try and get a picture of the hole I am talking about. Any help here would be soooo appreciated.
Thanks.
HMCS "Doc" McCoy SARC
Old May 7, 2018 | 06:19 AM
MiniToBe's Avatar
MiniToBe
yeah pix are good to add...is it an automatic or manual?
if automatic, here is the procedure to check the fluid:
https://www.newtis.info/tisv2/a/en/r...ission/4JnYJ1n
if manual, here is the procedure to check/fill the fluid:
https://www.newtis.info/tisv2/a/en/r...earbox/FjHdqsE
DRoc7822
Feb 15, 2016 12:47 PM
SooperCuperErik
Dec 16, 2011 11:58 AM
Marwan
Apr 23, 2011 08:29 AM
ortuna
May 23, 2010 10:33 PM
Mr. Incredible
Mar 20, 2009 11:22 AM
