R52 Trunk open light
Old May 2, 2018 | 01:52 PM
miniCPA's Avatar
miniCPA
Trunk open light
Is it a common problem to have the trunk/bonnet open light come on (and go off) randomly when driving? Is there a solution or a suggestion of where to start?
Pushing the trunk closed works for a little while but the problem comes back after a few miles.
I thought it was not too bad when it happened during the day. The inside light comes on but it is no big deal in daylight. Last night it came on several time is a 10 mile drive. Turning off the interior light only works until the next time the trunk open is triggered again.
Old May 2, 2018 | 06:46 PM
rkw's Avatar
rkw
It's a known problem with the switch that the tailgate presses on when closed. MINI updated the switch with a longer plunger. Order part 61319119052 from the dealer or Google the number for online vendors.
Old May 2, 2018 | 07:27 PM
MVPeters's Avatar
MVPeters
I thought it was not too bad when it happened during the day. The inside light comes on but it is no big deal in daylight. Last night it came on several times in a 10-mile drive. Turning off the interior light only works until the next time the trunk open is triggered again.
Put 2 or 3 layers of electrical tape where the plunger contacts the tail gate.
Old May 2, 2018 | 10:28 PM
rkw's Avatar
rkw
When it started happening to me, initially I would stick layers of stuff at the contact point but it would only work temporarily. I had to keep making it thicker and eventually tried a coin or two but the fix was never permanent. I learned (from this forum) that MINI had a service bulletin about it and that they had updated the switch. The new switch has a plunger that is substantially longer, by at least by a half inch.
Old May 5, 2018 | 01:57 PM
RLucky82's Avatar
RLucky82
mine had a cracked switch housing. all I did is pop the switch out press everything back together and pop it back in. took a total of 5 minutes. don't even think I used any tools. I always like to check the free stuff first. pull the switch out and take a look at it
Old May 7, 2018 | 05:54 PM
solomio's Avatar
solomio
Happened to me a few years back. I bough some stick on rubber bumpers (the type you would find under an old tv or laptop) at an electronic parts store. Its about 1/4 inch thick and stuck it onto the boot plastic section where the plunger makes contact. Works perfectly.
ImagoX
Feb 4, 2014 02:23 AM
Drockfresh
Oct 18, 2013 10:10 AM
nveerav
Feb 23, 2008 10:42 PM
MarioKart
Electrical
Oct 8, 2006 11:23 PM
Xeon
Oct 14, 2003 01:37 PM
