Spark Plug Wire Question
Old Nov 2, 2004 | 11:45 AM
GWestfall's Avatar
GWestfall
Hola! Love the board!
I have a quick question (please bear in mind that I am not the least bit mechanical). I have an '05 LY/B wht chk MCS and would like to put some different wires on it. Not anything performance related, purely for looks. I've read a few posts recommending the Kingsborne's. What I don't know is the difference between 8mm and 9mm and which ones I should use. Obviously there's a difference or they wouldn't make different varieties.
Any info would be great!
Thanks! Garrett
Old Nov 3, 2004 | 06:10 AM
GWestfall's Avatar
GWestfall
So does anyone know the answer to this? 48 reads with no replies?
Thanks!
Old Nov 3, 2004 | 06:19 AM
SumWon's Avatar
SumWon
Welcome to NAM!
If you are only concerned with appearance and you know you want the Kingsborne wires, then I would recommend you make your selection based on price. Which is cheaper, the 8mm or 9mm wires? Fundamentally, there will be no operating difference between the two in a none race situation. The theory [read marketing speak] between the difference is the larger wire will have less resistance, which boils down to a "hotter" spark. Hotter spark is suppose to equal more power. Again that’s the theory. Hope that helps.
Old Nov 3, 2004 | 06:42 AM
GWestfall's Avatar
GWestfall
Thanks! I appreciate your help.
Bublik
Feb 18, 2023 11:09 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
blackie
Aug 23, 2015 08:44 PM
yashmack
Aug 15, 2015 10:16 AM
