Navigation & Audio XM Direct install for HK equipped MCS
Old Nov 2, 2004 | 08:02 AM
Cooperb!'s Avatar
Cooperb!
Another $150 install - this time on an HK equipped 04 MCS.
Using the same XM Direct unit, and BlitzSafe XMD/BMW 100 (no pass through) Interface.
Antenna placement and cable routing is the same as before.
The difference is the HK module, found in the side compartment:
It's huge!
Takes up most of the available space, and at first glance we were convinced that the XM Direct and BlitzSafe would never fit in....
Also, the MINI wiring loom was taped under the HK module, and at first glance it looked like the necessary connectors were not there
However, they are just well taped to the MINI wiring, and some careful fishing about under the HK module freed-up the necessary connectors.
So, we spent some time playing with the BlitzSafe and XM Direct, looking for the best mounting points.
Ended up with the BlitzSafe going in first, between the HK and the tail-light - double sided tape to the inner skin.
Wires looped up over the HK unit, out of the way.
Then, XM Direct fitted to the HK unit with double-sided, to the right of the opening:
We toyed with putting the XM Direct module on the back of the compartment 'door', but opted for mounting inside the compartment.
Either will probably work, but we figured that the wiring would be less likely to be disturbed when the module was mounted inside the compartment.
The Audio L/R and control cables point straight up, and the antenna cable (purple) points down, and is coiled under the HK module.
So apart from the time spent looking at mounting options, it was a straightforward install, and sounded great over the HK system
Another happy XM/MINI
Chris.
Old Nov 2, 2004 | 06:23 PM
jeremyapp's Avatar
jeremyapp
would it be possible for you to tell me how you wired the antenna? I'm getting my XM Direct tomorrow and still am not sure about how to get the antenna wired. How do you get it up the side of the car? I couldnt find anywhere to run it when i did a quick look
Old Nov 2, 2004 | 08:49 PM
Cooperb!'s Avatar
Cooperb!
Check out my how-to thread here:
HOW TO INSTALL XM
That should explain it all.
If you still have questions, by all means drop me an Email.
chris@dodkin.com
Chris.
Old Nov 2, 2004 | 09:26 PM
MINIDean's Avatar
MINIDean
I have NAV and installed my XM direct by using the MINI Sirius bracket and then drill a small hole through my NAV antenna and wiring the antenna through that and down into the vehicle. Very stealth looking. I'd say I did a nice job. I installed this on the left side of the vehicle. For some reason I can't post my pictures, so I'll have to figure it out and post them later.
Old Nov 3, 2004 | 05:22 AM
LeeL's Avatar
LeeL
I did more or less the same thing with mine. However, I kept hearing a squeak or buzzing from back there so I eventually took the seat out and the side panel off to mount the XM box to the back of the seat post with ty-wrap and that cured the issue.
It also would have made the antenna feed much easier as I would not have had to reach way up through the hole to get the plug so for anyone who has the time (maybe an extra hour) and inclination, I would definitely suggest going that route.
Old Nov 4, 2004 | 02:15 AM
JZBIGZ1's Avatar
JZBIGZ1
XM Direct install for $150
If you have cd changer in the back it will have removed right.
Old Nov 4, 2004 | 06:14 AM
Cooperb!'s Avatar
Cooperb!
Yep CD changer comes out to gain access to the panel I believe.
Chris.
Old Nov 4, 2004 | 10:07 AM
DrkSilvrMini's Avatar
DrkSilvrMini
Can anybody tell me where to get the modules I need to Hook XM up to my 03 MCS?
Old Nov 4, 2004 | 01:02 PM
Cooperb!'s Avatar
Cooperb!
You can buy online from HERE
Or a number of other online retailers.
Chris.
Old Nov 4, 2004 | 01:14 PM
MSFITOY's Avatar
MSFITOY
$150 install??!!?? I have the same kit and installed it in less than 5 minutes
Old Nov 4, 2004 | 01:16 PM
Cooperb!'s Avatar
Cooperb!
That's $150 for the hardware, not the installation!
As discussed here, it's an easy self install.
Chris.
Old Nov 4, 2004 | 01:33 PM
MSFITOY's Avatar
MSFITOY
Chris.
Wow...where did you get the set up for $150? That's a great price.
Old Nov 4, 2004 | 02:02 PM
meanboy's Avatar
meanboy
It was a great price! Blitzsafe clamped down on it and it looks more like $250.00 now.
Old Nov 4, 2004 | 06:15 PM
Cooperb!'s Avatar
Cooperb!
First set was from BS direct and Crutchfield. $150 + post
That deal is now being throttled at birth by the manufacturer
This set was from EBAY $150 + post
Chris.
Old Nov 6, 2004 | 06:31 PM
Addsy77's Avatar
Addsy77
'05 cabrio install
Has anyone installed this on a 05 convertible? Is it true the MINIs antenna can work with the direct xm? I want to purchase this but need to make sure..... thanks !!
Old Nov 6, 2004 | 08:57 PM
Addsy77's Avatar
Addsy77
direct xm prices
Googled the part and these are the prices I found... think I'll hold out awhile and hope that Blitzsafe does a group buy for us
http://caraudio.discountdirect2u.com/xm.htm
$225.49
http://www.electronicsopticsandmore....x?prdId=178826
$239.99
http://www.audiooutfitter.com/store/BLZXMDBMW100.html
$241.16
Old Nov 7, 2004 | 12:38 PM
Silver708's Avatar
Silver708
Blitzsafe adapter for XM direct
Hey everyone, I was reading all of the previous blogs and was doing research on these adapters. and was wondering if these adapters you are talking about are found at:
http://www.myradiostore.us/auxadapters/blitzsafe/
Are these the right ones? and if so, they arn't going to cost you too much
~ $100 - $110 for the Mini adapter.
Please tell me if I am wrong. I am interested in purchasing these.
Old Nov 7, 2004 | 10:01 PM
Cooperb!'s Avatar
Cooperb!
These are not the right ones I'm afraid
They are only for interfacing things like CD changers or iPods etc.
The XM Direct Interface is a different model XMD/BMW 100 or 101
Don't buy any other models, or you'll be dissapointed when you can't control your XM Direct from the MINI controls.
Chris.
Old Nov 8, 2004 | 04:44 AM
miniquick's Avatar
miniquick
Addsy77:Has anyone installed this on a 05 convertible? Is it true the MINIs antenna can work with the direct xm? I want to purchase this but need to make sure..... thanks !!
I have the same question?
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
squawSkiBum
Oct 2, 2015 09:21 AM
flredmini
Aug 12, 2015 06:35 PM
massmini03
Aug 12, 2015 11:19 AM
