R56 R56 Exhaust Question
Old Apr 22, 2018 | 07:19 AM
gkp's Avatar
gkp
I've been under the car 100 times but recently noticed for the first time that there is a lot of play — maybe 2 inches — in the exhaust system where the pipe meets the back end of the cat. Is this normal? At first I thought I lost a clamp but I checked the exhaust diagrams and there is no clamp there. It looks like the pipe just inserts into the cat. What made me check was that my exhaust sounded louder to me so I was looking for leaks.
Old Apr 22, 2018 | 08:39 AM
bcriverjunky's Avatar
bcriverjunky
Clamp is missing. https://www.ecstuning.com/b-genuine-...p/18302756352/
Old Apr 22, 2018 | 04:20 PM
gkp's Avatar
gkp
That's what I thought at first. In fact, I bought the clamp. But there's no lip on the pipe for the clamp. When I look at the parts diagrams, no clamp is shown.
Old Apr 22, 2018 | 06:18 PM
bcriverjunky
The two pipes fit together like a ball and socket. The clamp fits over the two. Random photo from the net. Not my mess..
Old Apr 22, 2018 | 07:07 PM
jcwcoopster's Avatar
jcwcoopster
Yes clamp number 3 in the diagram is what your missing. Did someone recently do some work on your vehicle and inadvertently forget to re-install?
Old Apr 23, 2018 | 07:18 AM
MiniToBe's Avatar
MiniToBe
I beg to differ...the OP is showing a pix AFTER the flex pipe not right after the bend. there is no clamp in that area...make sure your welds are not broken.
I did an engine rebuilt and it snapped at that location. took the whole thing to a shop to get it welded.
Good luck.
Old Apr 23, 2018 | 05:12 PM
gkp's Avatar
gkp
Originally Posted by MiniToBe
I beg to differ...the OP is showing a pix AFTER the flex pipe not right after the bend. there is no clamp in that area...make sure your welds are not broken. Good luck.
Exactly. It's after. If there are supposed to be welds then they're definitely broken. No idea how that happened. Thanks.
Old Apr 23, 2018 | 05:20 PM
bcriverjunky
Good luck.
Good call. I kept wondering why it looked a little off to me.
Old Apr 23, 2018 | 06:21 PM
jcwcoopster
Good luck.
My bad I went off the wrong picture.
Old Apr 23, 2018 | 06:23 PM
jcwcoopster
Do you drive your Mini in the winter months of the North East? I grew up in Connecticut and when I had vehicles like my honda accord the flex pipe at the joint broke on two of my vehicles. I suspect it was from the harsh road salt chemicals of the winter seasons.
Old Apr 24, 2018 | 05:49 AM
gkp's Avatar
gkp
Originally Posted by jcwcoopster
Do you drive your Mini in the winter months of the North East? I grew up in Connecticut.
I haven't driven it much the past few winters but I did when it was newer. And I can tell you that the chemicals they are using on the roads here in CT nowadays are toxic to cars so that could be it. Mechanics everywhere have horror stories.
Thanks, all, for your help. I should have been clearer at the start and posted this:
Old Apr 25, 2018 | 01:53 PM
bugeye1031's Avatar
bugeye1031
Moderator
My R55 exhaust looked just like that after about 140,000 miles (New England - including winters). It was weird because it didn't sound bad, but I could slide the thing apart....it just kind of hung together until I had it welded. The weld lasted about 15,000 miles.
DivineXtacy
Apr 6, 2015 10:31 AM
immo
Jul 23, 2014 11:14 PM
AtypicalStyle
May 24, 2013 12:02 PM
twstlvr
May 7, 2003 07:12 AM
