R55 2011 R55 Cooling Fan Test
Old Apr 19, 2018 | 09:33 AM
shade tree mechanic's Avatar
shade tree mechanic
Radiator cooling fan was not working. Finally got the power connection on the rear of the fan assembly apart and reconnected to ensure tightness. Fan now runs on low speed when engine is warm, but not fast enough to cool anything. Unfortunately I don't have a dashboard temp guage and only have "Oops" lights on the dash. Water pump and thermostat have been replaced in the last year. Is there a way to test the fan with 2 leads like testing the fans from earlier years with 3 leads? Not opposed to replacing the assembly if needed, however I replace parts to correct the problem instead of trying to locate the problem.
Old May 4, 2018 | 08:16 AM
MiniToBe's Avatar
MiniToBe
there are two relays next to the DME...one is for Fan stage 1 and the other is for Fan stage 2. check these relays and you might be able close the contacts for testing there rather than at the fan plug.
check https://www.newtis.info/tisv2/a/en/r55-cooper-s-clu/ if S model
or https://www.newtis.info/tisv2/a/en/r55-cooper-clu/ if non-S
jeffl
Aug 30, 2014 03:34 PM
JPMM
Oct 10, 2011 02:58 AM
Dan1967
Sep 19, 2010 04:36 PM
mpdwag
Aug 7, 2008 04:45 PM
ilscoobydooll
Jun 4, 2007 02:47 PM
