R52 Vibration on idle
Old Apr 11, 2018 | 01:48 PM
rauls4's Avatar
rauls4
Vibration on idle
My beloved new-to-me 2008 JCW vibrates quite a bit while idle. If I rev up a bit the vibration goes away. Any recommendation on common causes and fixes?
Old Apr 11, 2018 | 01:56 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Join the club relative to the rattles. The verts shake more as there is no lid to tie things together.
Old Apr 11, 2018 | 01:57 PM
rauls4's Avatar
rauls4
I mean, it's not horrible, but definitively noticeable.
Old Apr 11, 2018 | 02:05 PM
Whine not Walnuts
I have put rubber strips between the x braces and the fuel tanks, rubber o-rings at suspension to body connectors and an ATI crank pulley. The first helped remove some at the rear, the second helped a little but the handling suffered and the third did nothing. I have one rattle in the back that I think is the plastic tailgate interior trim but it goes away when the car is warmed up a little.
There is thread here somewhere on a guy that took the dash apart and put some surgical type tape at all the joints.
Turn the radio up and get use to the rear view mirror image looking like there is vasoline smeared on the mirror.
Old Apr 11, 2018 | 02:08 PM
rauls4's Avatar
rauls4
LOL. Thanks
Old Apr 11, 2018 | 02:25 PM
Capt_bj's Avatar
Capt_bj
with the age of the car you may want to check the condition of the motor mounts ....
rauls4's Avatar
rauls4
Good point. I was thinking of replacing them anyway.
Old May 10, 2018 | 11:57 AM
Rebound's Avatar
Rebound
Motor Mounts
Please take a look at the photo I posted in this section about the PanAm Mini. The photo shows where to look for leaking hydraulic fluid which will indicate a failed passenger side engine mount.
I didnt consider this replacement too hard. Pelican Parts has a good tutorial on their website, although I didn’t need to remove the wheel liners. You’ll definitely need a good floor jack, four jackstands, a solid, stable floor to work on, and that’s about it. The rest is basic 3/8” and 1/2” ratchets, breaker bars, extensions and torque wrench. The only special tool is an E12 socket for removing one bolt. (There’s no shortcut; you must have that socket). I noticed a HUGE reduction in vibration after doing this. Some rattles remain, but you can’t fix rattles if your car vibrates so badly.
Old May 10, 2018 | 01:49 PM
rauls4's Avatar
rauls4
Fantastic! Thanks for the info, I will put it on the top of my to-do list
CARdiac
Dec 30, 2009 09:30 AM
kgardnez
Oct 25, 2008 08:41 AM
BentChainring
Sep 21, 2007 08:13 PM
mdsbrain
Oct 14, 2006 05:51 AM
SpiderX
Suspension
May 11, 2006 02:47 PM
