R56 Drive Belt Size 2007 Hatch DOHC
Old Apr 11, 2018 | 10:29 AM
carwhisperer's Avatar
carwhisperer
Simple question for which I cannot find the answer. What is the accessory drive belt size for my 2007 Base Hatch 6 speed with AC? Is it 1050mm/41.25 inches? That seems to be the most likely so far.
Old Apr 11, 2018 | 11:53 AM
LostbutFound's Avatar
LostbutFound
To state the obvious 1050 mm equals 41.33 inches. I would say they are the same.
Old Apr 11, 2018 | 01:45 PM
carwhisperer
Thanks but I see that my question was not worded very well. I know those numbers are equivalent. I am asking if 1050mm/41.25inches is the correct belt length for my car.
Old Apr 11, 2018 | 02:21 PM
LostbutFound
Sorry, the "or" got me. Wondered why you would worry about less than a tenth of a inch.
Old Apr 11, 2018 | 02:30 PM
carwhisperer
I'm still not communicating very well. My question is this:
Is 1050mm the correct belt length for a 2007 Mini Cooper Hatch Base (no turbo, DOHC)?
Old Apr 14, 2018 | 06:07 PM
carwhisperer
The answer is no. I got that size from Oreilly's, because their system said it would fit. It was way too long. So I had to jump on the motorcycle all greasy and go get another one. I brought the old one with me to Napa. My old one was 905mm. The closest they had was 903. It went right on. Changing it wasn't that hard. I found that a 13/16 wrench would fit on the tensioner release. But I had to bend my wrench in the vice with a hammer. It needed to be pretty much flat to fit between the engine and lower frame rail.
bcacres
Nov 3, 2010 07:29 PM
british RACING green
May 27, 2009 09:10 AM
fairladyz_gt-r
Apr 3, 2007 09:13 PM
RandyS
Feb 6, 2003 10:59 AM
