R56 Tail light needs replacing??
Old Apr 5, 2018 | 04:10 PM
harley0711's Avatar
harley0711
OK,, left turn signal seem to be out.. looked at the bulb, looked ok,, did a test, still ok... Hummmmm
took off chrome ring, checked the plug connection,, BINGO,, One of the connectors, prongs burnt out???? WTH...
So,,, now looks like I need a new tail light And a new plug???
Anyone have this happen and where is the best place to buy a new tail light....
Old Apr 5, 2018 | 04:38 PM
vetsvette's Avatar
vetsvette
Moderator
I have a pair of tail lights from a '07 MCS that I'll part with.
Old Apr 5, 2018 | 04:59 PM
harley0711's Avatar
harley0711
very nice... I did find a replacement from
carparts.com
Shopping Cart
Save Quote or Continue Shopping
Item Qty Subtotal
Replacement Halogen Tail Light - M730128 - Driver Side, Amber & Red Lens, w/o Bulb(s), Hatchback
Part No.: M730128
Remove
In stock
1 x $30.96
$30.96
Add Protection Plan
Include Lifetime Protection Plan for ($9.99)
I am in Turlock CA
Old Apr 5, 2018 | 05:36 PM
rkw's Avatar
rkw
carparts.com
Shopping Cart
Item Qty Subtotal
Part No.: M730128
Remove
In stock
1 x $30.96
$30.96
Add Protection Plan
I am in Turlock CA
That's the plastic housing, which is not your issue. The electrical part you need is either #5 or #10 in the diagram here: http://www.realoem.com/bmw/enUS/show...diagId=63_0996. It would help if you post a photo that shows the problem in the connector.
Old Apr 5, 2018 | 06:22 PM
harley0711's Avatar
harley0711
Ya I also just figured that out.. I need #10 and the plug that goes into it... one of the prongs burnt off?????
Old Apr 5, 2018 | 06:23 PM
harley0711's Avatar
harley0711
I will try to take a pic tomorrow... pretty hard but I will try....
Old Apr 5, 2018 | 06:32 PM
harley0711's Avatar
harley0711
Old Apr 5, 2018 | 09:06 PM
rkw's Avatar
rkw
#10 is easy to find, just Google the part number (63212756179) for vendors.
The connector will be harder to track down. It is X319 in the wiring diagram (https://www.newtis.info/tisv2/a/en/r...r-hat/CTCu0hTl), but I don't see it as a separate item in the parts catalog. It comes with the entire wiring: https://www.outmotoring.com/wiring-rear-left.html. You should check if the connector has a part number on it.
Old Apr 6, 2018 | 07:15 AM
harley0711's Avatar
harley0711
I think this will work?
https://www.autopartskart.com/sku/rb...waAizPEALw_wcB
or
Amazon Amazon
autozone??
https://www.autozone.com/collision-b...l=cooper&year=
Old Apr 6, 2018 | 12:13 PM
rkw's Avatar
rkw
Good find! Those look like the right connectors.
Old Apr 6, 2018 | 04:14 PM
harley0711's Avatar
harley0711
Parts ordered , I will post after I am done
This is a strange one - bought this Mini new 10 yeats ago. Not sure why this terminal burnt the way it did. At first, I thought it was just a burnt out bulb for the turn signal. Who ever designed that hole / reach in twist bulb out and replace ///// should be WHIPPED, lol
Finally realized All were out - learned how to remove chrome ring on tail light - 3 torx screws and it was out... Duhhhhh
Old Apr 10, 2018 | 02:21 PM
harley0711's Avatar
harley0711
just got my new parts and replaced both the Bulb holder and the plug/pigtail that goes into it.. For what ever reason - one of the connectors in the plug/pigtail burned out???
was super easy to change.
the part number and place I got the bulb holder was
RM European auto parts # 63-21-2-755-179 about $26
plug/pigtail I got thru Autozone because I was not 100% sure it would fit but it did
#Dorman 645-733 Tail Light Harness could even get this from Amazon
Old Apr 10, 2018 | 05:13 PM
rkw's Avatar
rkw
Are you saying that you replaced the parts but it immediately burned out again?
Old Apr 10, 2018 | 06:30 PM
harley0711's Avatar
harley0711
sorry, no... they work fine.... Just have no idea why it burnt in the first place
Old Apr 12, 2018 | 06:33 AM
Seen the taillights melt at the bulb connection but not at the harness. Most of the time its arching of the bulb connection.
teinesina
Nov 1, 2014 09:19 PM
Angryriican66
Jan 1, 2014 02:39 PM
Thom228
Mar 13, 2013 07:37 PM
minimonkeygrrl
May 11, 2007 10:11 AM
PDX_Mini
Oct 2, 2006 06:45 AM
