R55 Just got my Clubman back...
Old Mar 21, 2018 | 08:59 PM
Tim Dunbarr's Avatar
Tim Dunbarr
...after having a reman engine put in.
First, brake light on the dash is on (yellow). No problems with brakes, tail lights are all working (see next statement for additional info), but I can't figure it out.
Second, my backup light is always lit and my rear sensor warning goes off if something gets to close to the rear of the car - even if I'm driving or in neutral. Is it possible to easily cross a wire when putting the transaxle back in? Maybe this is part of the issue with the brake warning light on my dash?
Third, my BOV isn't working. Does this:
Have something to do with that? And if not: 1. Where does that plug belong and 2. How do I check the function of the BOV?
Other than these issues, the rebuilt motor runs like buttah. Lots more power than the one I had in the car before (I think one of the previous owners drove the car pretty hard).
Thanks for your help and ideas, guys!
Old Mar 23, 2018 | 12:21 PM
MiniToBe's Avatar
MiniToBe
that is the plug that sits under the engine wiring harness.
check the plug that goes into the shifter mechanism.
in general, you paid for a service and they should take care of these issues. give them a call reporting these issues to them.
Old Mar 25, 2018 | 02:19 PM
Tim Dunbarr
Oh for the love of...
Got all those issues sorted out, but now I've got another.
I'm hearing a quiet metallic grinding/whirring noise from the passenger side of the engine, and when I turn the car off the fan in the engine bay is going full blast for about a minute. Coolant reservoir is still full, no leaks anywhere.
Water pump?
Old Mar 25, 2018 | 07:04 PM
Bnourai's Avatar
Bnourai
Or thermostat sensor.
Old Mar 25, 2018 | 07:07 PM
Tim Dunbarr
Would that create that metallic sound? Almost sounds like a bad bearing.
Old Mar 29, 2018 | 12:28 PM
Tim Dunbarr
So, good news and not quite horrible news. It's not the water pump that's broken, but the friction wheel. Little more expensive and I'm having to replace a pulley and the serpentine belt with it. It's not as invasive as pulling the water pump out of the engine, but a little more difficult to get to the bolts holding the friction wheel on. Ah, the joys of Mini ownership.
Mini for life!
R55 :: Clubman Talk (2008+)
Dec 30, 2013 02:25 PM
STLMINI
Sep 12, 2008 04:05 AM
yudman
Dec 3, 2003 12:31 PM
Storer
15
Oct 27, 2002 06:55 PM
