Bonnet Stuck Shut on 2013 R60S
Old Mar 16, 2018 | 12:10 PM
NCapurata's Avatar
NCapurata
Angry Bonnet Stuck Shut on 2013 R60S
Hi guys,
I'm looking for some guidance or insight on how to release open the bonnet on a 2013 R60.
I attempted to open the bonnet of the car in preparation for an in-between oil-change and I wasn't able to release the bonnet when pulling on the release handle.
Doing a little searching I came across some videos that highlight a possible failure or disconnect of the cable (white clip) from the bracket at the release handle end and checked that. I was able confirm that the cable (white clip) did not jump off from the bracket and the bracket does not seem to show any indications that it bent forward.
When pulling on the release handle, there is slight tension at the end of the trajectory, but no sign of the latches unlocking.
When looking at the bonnet I can confirm that the locking latch on the driver's side seems to have disengaged as I can try to lift the bonnet slight and there is give. The issue seems to be on the latch that is located on the passanger's side. I am not able to get the same play on that side that there is on the drivers side.
I tried pressing down on both sides to see if it disengages and the passanger's side does not give, and I cant seem to get the drivers side to engage again and lock.
I have read some notes that speak to pressing down on the hood where the latches would be located while someone else pulls the cable, and that has not proven to be fruitful either.
It almost seems like the restraining clip/bracket at the edge of the passenger's latch has come lose. the cable is pulling, but since there is no resistance at the end (white clip) the cable flexes and does not disengage the hood.
Any pointers, instructions or links to video outlining how to unlock a bonnet from the outside would be helpful. Also, has anyone else experienced something similar?
I'm hoping to get the hood open so that I can assess if the cable itself needs replacing or lubricating, etc.
thanks in advance.
Old Mar 17, 2018 | 06:43 AM
Mark Bielick's Avatar
Mark Bielick
Mine had the same failure. I ended up having to tear out the entire footwell in order to repair the pull lever. It is a poor design in that the cable attachment can come loose from the mounting bracket, resulting in the cable not working. Once I was able to manually pull the cable, I had helpers push down on the hood, and the latches released. Poorly designed system in my opinion. The other issue that you may be seeing is where the single cable converts to two separate pull cables. Unfortunately, you can't get to this location unless the hood is open.
Old Mar 18, 2018 | 06:10 PM
NCapurata's Avatar
NCapurata
Thanks Mark. Was yours same make/ model year? Did you have to remove the wheels on both sides, or were you able to access the wheel wells and remove the liners without tire removal? Are both latches in a similar location?
Thanks for your comment.
Old Mar 19, 2018 | 08:36 AM
Mark Bielick
Mine is a 2011 All4. I was able to repair the hood latch without having to do anything with the wheel wells. I removed the footwell side cover where the pull lever is mounted. The metal bracket had bent to the point where it would not hold the cable housing firmly. This caused the entire cable to move, but did not allow the cable to pull the latches under the hood. Once I was able to manually pull the cable wire,I had a helper push down on the hood. This released the hood latches. I then had to re-bend the bracket to hold the cable. I crimped it tighter on the cable housing, and I also lubricated the cable with graphite to reduce the stress on the bracket. I still wince every time I have to open the hood.
datanerd
Oct 1, 2025 08:45 AM
austin5
Jun 12, 2019 02:41 PM
indianainline
Nov 20, 2016 09:26 PM
Firewire
Sep 22, 2012 05:28 PM
