R50/53 Mystery Button - what does it do?
Old Jun 19, 2002 | 12:19 PM
zogbogbean's Avatar
zogbogbean
I found a button that is kind of hidden located on the underside of the center console. While looking for the trunk release (before I relized that the thing is already unlocked when the doors are unlocked.. duh!) I felt a push button under there. Does anyone else know what it is for? I pressed it twice and nothing seemed to happen. I didn't see it listed in the manual either.
Old Jun 19, 2002 | 12:36 PM
Sfiveten's Avatar
Sfiveten
zog,
It depends on what button you are talking about....
If your talking about the button located under the E-Brake..... that is for the air pressure sensors. That has been discussed here before. Here...
If your talking about a button located under the drivers side dash.... I think it has something to do with the computer..... ie reset button or something.
Hope this helps.
SW
_________________
Motor On!!..... Mini Me!!
Old Jun 19, 2002 | 12:46 PM
MiniDreaming's Avatar
MiniDreaming
If it is the one under the dash it is the Eject button for the passeger seat. Not recommended if you don't have the double pane sunroof open. Works great for wife, in-laws, neighbors and pets.
Happy Mini Motoring!
Old Jun 20, 2002 | 09:29 PM
bmwman469's Avatar
bmwman469
Is the ejection seat a cost+ option... that might be useful.
Old Jun 20, 2002 | 10:57 PM
Newman's Avatar
Newman
DON'T TOUCH THAT! IT WILL ERASE YOUR PERSONAL SETTINGS FOR MINICOOPER ONLINE!!!
Truly, I think what you are talking about is the fuel reset switch or pump reset switch. Designed to shut off in case of impact... Would need to see exactly which button you be touchin.
Old Jun 21, 2002 | 12:03 PM
Johnna's Avatar
Johnna
The spring loaded button under the toggle switches? Don't know for sure but it comes in handy for replacing the closure panel if, for some reason, you should knock it loose.
Filmy
15
Jun 6, 2023 06:27 AM
Peking Duck
Jan 19, 2021 03:17 AM
Filmy
Jun 28, 2016 08:58 AM
eMINI of the State
Oct 2, 2015 03:12 PM
misterbl
Sep 16, 2015 11:22 AM
