R55 Odd problem with brake lights
Old Mar 10, 2018 | 06:00 PM
Foxtrot3000's Avatar
Foxtrot3000
Hello,. I have a 2010 Clubman and for some reason ever since I had to replace my battery my lower brake lights won't work but the parking lights do and since it's a single filiment bulb I don't understand it. If I unplug the bulb I get the light out on the dash but when plugged it they don't work for anything but parking lights. The 3rd brake light is working fine though. If my head lights are on the parking light works and if I push the brake peddle it shuts off. Any thoughts?
Old Mar 10, 2018 | 08:54 PM
rkw's Avatar
rkw
What do you mean by "lower brake lights", because the 2010 Clubman only have a dual filament brake/parking light on top.
From the Owners Manual:
Old Mar 10, 2018 | 08:58 PM
Foxtrot3000
What I meant was the two lights marked as 1 on that I just think of them as lower and the 3rd as upper. Sorry. But yeah my mini only has single filiment bulbs in it? When I take them out there doesn't look to be contacts for a 2nd filiment?
Old Mar 11, 2018 | 04:31 AM
rkw's Avatar
rkw
If your bulb holder looks like this and the bulb socket is marked P21W, then the bulb should indeed be single filament (P21W is a type of bulb).
The wiring diagram shows pin 1 of the connector to be the parking light signal and the brake signal is pin 6 (left tail light) or pin 5 (right tail light). All of the signals come from the footwell module, which controls lighting. My guess is that the footwell module feeds a lower voltage signal to pin 1 (for a dimmer light) and full voltage for the brakes, but doesn't run both simultaneously (pressing on the brakes cuts the signal to pin 1). Unfortunately this suggests a possible failure in your footwell module, which is expensive to replace. You need to have a dealer or shop diagnose it.
Old Mar 13, 2018 | 11:10 AM
Foxtrot3000
Okay yeah I think my frm is dead. After doing a battery pull again I no longer have the ability to shut off my headlights and I no longer have turn signals. Going to start looking for a good frm soon to replace it
Old Mar 24, 2018 | 12:21 PM
turbotraveller's Avatar
turbotraveller
wires for rear lights are multiplexed, they do more than one task. i forget the combination, but the tail lights, reverse light, fog light, turn signal and brake lights are controlled by just three wires with two of those wires sharing duties. it took me quite a while to figure trailer wiring and it seemed that different years use different color wires
peeti
Oct 21, 2011 11:56 AM
Divide Wee
Nov 22, 2009 05:41 PM
blkkouki
Nov 16, 2008 05:14 PM
pc
Oct 10, 2007 05:29 AM
Noisegirly
Jul 25, 2005 12:32 PM
