R50/53 Strut Assembly Parts
Hello all!
I am replacing the struts and springs on my '02 MCS, and I am curious as to where I can get the lower seats for the springs and what other pieces I need besides strut mounts in order to make the full assembly without having to disassemble the old ones. I already have the new Koni Yellow struts, H&R springs, and new strut top mounts. In doing some research, it only seems that I am missing the lower spring seats, but I have heard I might need other new parts to complete it. Any info would be greatly appreciated.
Thanks,
Ken McKay
Thanks,
Ken McKay
We can get them all for you as you will need all the parts for the upper mounts and bump stops. it will add up quick as they aren't as cheap as you expect.
But they are easy to take apart you don't even need a spring compressor to take apart so I would just save your money and take the old ones apart.
Also we could sell you the parts used from one of our parts cars to save you a bunch.
I am looking at the Powerflex bump stop kit for my 02 MCS and wondering if you have any previous experience in using the kit. It says it is a universal kit, but does not say if it is for two struts, four struts, or what. Thoughts? I would rather not put the old equipment on the new struts and springs. Trying to update as much as I can, and aware that it is going to cost.
this powerflex bump stop set is for 2 struts
https://www.waymotorworks.com/powerf...-stop-kit.html
They wouldn't work for the rears as they are too large.
so in the rear I just use the stock ones
https://www.waymotorworks.com/stock-...0-r52-r53.html
Then use the rear powerflex upper shock mounts
https://www.waymotorworks.com/powerf...-bushings.html
Otherwise used stuff is fine as the metal mount parts, and spring rubbers last.
brightside
Nov 10, 2017 07:56 AM
redhotchilipepper
Oct 21, 2017 06:53 PM
Kyle
Jul 4, 2005 09:55 PM
