Drivetrain Tuning options
Old Mar 8, 2018 | 10:10 AM
socalva's Avatar
socalva
Tuning options
I used the search function but it seems somerecommendations are no longer in business (Mynes). What are the current remote tuning options other than RMW? It looks like ByteTronics is the only other player but remote tune requires an wideband O2 sensor install. Anyone have recommendations for local tuners in the SoCal area?
Old Mar 9, 2018 | 07:31 AM
astroblackr53's Avatar
astroblackr53
Mynes is more/less Bytetronics. For reliability your best bets are RMW or Bytetronics, both are similar if you are looking for a software tune.
If you are wanting/able to tackle the tuning yourself than your option is Bytetronics, I use this and have had solid success for my needs.
Old Mar 11, 2018 | 11:38 AM
Revolution Motor Works's Avatar
Vendor
I'm in Anaheim and dyno tuning is in Wilmington for custom dyno tunes
Old Mar 11, 2018 | 01:19 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I have a RMW tune, all done in my garage. Yes it takes longer by the time you send the files back and forth and there may be some glitches but Jan at RMW stayed on the issue and I am very satisfied.
Old Mar 13, 2018 | 11:44 AM
koreycon's Avatar
koreycon
what the guy up top said...Installing my RMW tune this weekend, super stoked!
Old Mar 13, 2018 | 12:30 PM
Whine not Walnuts
I suggest you disconnet the power steering pump fuse first. It is under the engine fuse box, have to remove the ecu in order to flip the fuse box over. Be sure to disconnect the negative battery terminal first. Its the 100 amp fuse, watch the you do not lose the small screws. By doing this the battery voltage will not drop while you are loading programs.
Old Mar 13, 2018 | 12:31 PM
Whine not Walnuts
just like a little kid in a candy jar . . . . . .
Old Mar 13, 2018 | 12:36 PM
koreycon's Avatar
koreycon
Thanks!
SpeedRacer0212
Apr 3, 2012 02:00 AM
Singha
Aug 25, 2011 11:44 PM
DanQ
Cooper (non S)
48
Mar 2, 2009 08:21 PM
Schwinn
Sep 12, 2008 12:03 PM
MedicMan55
Aug 20, 2006 03:19 PM
