Recommendations for Brake Pads?
Old Mar 7, 2018 | 11:50 AM
Heifzilla's Avatar
Heifzilla
I’ve got a 2014 F56 Justa that needs to have the brakes done. My dealer wants $1400, which is crazy *** insane, even for BMW. My husband has done brakes before and will do mine, but he wanted me to find out what pads are people recommending and if there is anything he “should know” before doing them.
Thanks in advance,
Heif
Old Mar 7, 2018 | 03:18 PM
Whine not Walnuts's Avatar
Whine not Walnuts
You talking fronts and backs? I don't know about the Gen3's but the Gen1 rear piston must be turned to retract back in. Would think some will chime in here.
Some of the vendors here might have the pads you need as well.
Old Mar 7, 2018 | 03:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've been using the EBC reds and very happy with them.
https://www.waymotorworks.com/14-f56...s/brakes/pads/
Old Mar 7, 2018 | 07:26 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Some brake install info https://www.newtis.info/tisv2/a/en/f...kes/1VnXtihcMI
Old Mar 7, 2018 | 08:33 PM
Heifzilla's Avatar
Heifzilla
Originally Posted by Minnie.the.Moocher
Excellent, thank you. Hubby will appreciate this.
Old Mar 7, 2018 | 09:04 PM
Heifzilla's Avatar
Heifzilla
Great, thank you.
Old Mar 7, 2018 | 09:05 PM
Heifzilla's Avatar
Heifzilla
Originally Posted by Whine not Walnuts
You talking fronts and backs? I don't know about the Gen3's but the Gen1 rear piston must be turned to retract back in. Would think so will chime in here.
Yep, fronts and backs. Good info to know, thank you.
Old Mar 10, 2018 | 07:15 PM
bratling's Avatar
bratling
Super Moderator
Gen 3 also has the annoying rear piston design. I assume there is a reason for it but darned if I know what it is. If you don't have the special tool you can make do with a set of long nose pliers to apply push and twist.
Another vote for EBC RedStuff. Great street pads! For rotors get the house brand from WayMotorWorks.com. As good as OEM, less expensive, and unlike OEM has an anti-corrosion coating that helps keep it looking nice.
I have no connection with WMW, just a satisfied customer for years. Way is my go-to for parts, supplies and advice.
Old Mar 12, 2018 | 09:08 PM
Heifzilla's Avatar
Heifzilla
Does anyone know what part number the piston pusher tool is or have a link where I can get one?
Thanks again!
Old Mar 13, 2018 | 05:28 AM
Whine not Walnuts
I think this the part you are looking for, Neiko 20733A Disc Brake Caliper Wind Back Tool Kit.
Amazon has it but I think you can buy either this or something similar locally. You should also check with some local autopart stores as they may rent them.
Old Mar 14, 2018 | 09:44 AM
Pgh Performance Parts's Avatar
Pittsburgh Performance Parts would be happy to get the brake pads for you. We have both EBC and Hawk brake pads. We are also giving a 10% discount on first orders until March 31st.
Old Mar 15, 2018 | 04:58 AM
Capt_bj's Avatar
Capt_bj
https://www.harborfreight.com/disc-b...-pc-63264.html
https://www.outmotoring.com/mini-coo..._tool_set.html
Amazon Amazon
Amazon Amazon
p.s. the need to rotate is a part of the e-brake system. The various adapter plates in the kits reflects the commonality of this system ... the adapters allowing the tool to work on many makes and sizes of calipers ...
Old Mar 15, 2018 | 06:24 AM
RudeJoe's Avatar
RudeJoe
I assume its related to the parking brake since it is a mechanical actuation.
______
Since you're also in salt country make sure he checks that the caliper slides easily on the guide pins. Not sure if the 3rd gen is the same as the 1st but on the 1st gen corrosion (hard white buildup) accumulates under the rubber slide pin boots on the caliper.
Here's a link to what we found on my son's R50.
https://www.northamericanmotoring.co...corrosion.html
Old Mar 17, 2018 | 10:07 PM
B17overhead's Avatar
B17overhead
Pads
Those of us autocrossing hard where the brakes gets smoking hot have found the stock pads are fine. The EBC and so on should be ok too, but probably not necessary. There was zero aftermarket pad availability last year for the 3 Gen f56, so maybe that has changed and you have a choice now.
lindseybp
Oct 3, 2014 11:56 AM
ChrisWyso
Tires, Wheels, & Brakes
Oct 14, 2012 02:18 PM
yyj3869
Oct 1, 2011 07:08 PM
CasperMimi
MINI5280
Aug 25, 2007 05:50 PM
