Navigation & Audio Garmin BC-30 Camera, anyone installed one?
Old Feb 12, 2018 | 07:58 AM
Lucas63's Avatar
Lucas63
Has anyone installed the Wireless Garmin BC-30 camera in a Clubman?
Just purchased a DriveSmart 61 LMT-S and the back-up camera would be a nice addition. Haven't really looked over the car yet, but seems like the choices to mount the camera are very limited.
Old Feb 18, 2018 | 04:33 AM
umberto's Avatar
umberto
I bought a garmin Nuvi (i forget which model but i made sure it was BC-30 compatible) and the BC-30 at best buy and for $60 more they did the install on the BC-30 back up camera ...they hid all the wiring perfectly ....the transmitter is in the headliner above the boot and the receiver which is taped behind the Nuvi GPS is positioned semi-permanently in the space below the radio in front of the shifter, so a direct line of sight from transmitter to receiver ...note: my car is a 2016 4 door MC, not a clubman ....the back up camera works just fine even in very very dim lighting conditions ,,,syncs fine as the GPS screen switches to back up camera about one second after reverse is engaged ...also the guidelines are easily adjustable L and R and distance behind the car to whatever you are backing up into
Old Feb 18, 2018 | 06:07 AM
Lucas63's Avatar
Lucas63
Nice. It seems that the hatchbacks are the easiest to install a camera. The Clubman is going to be a challenge. The factory camera would have mounted in the bumper above the license plate, so it's low to the ground. There isn't a knockout in that area on my car so a hole needs to be drilled. Then the wire on the BC-30, I'm told by Garmin is only 4' long between the camera and the transmitter, so it needs the 50' extension they sell to route the wire from the bumper into the right or left rear door to tap into the reverse lights. Then all of this my not even work because of LED reverse lights that I think the car monitors the voltage usage of and it may need coding to prevent an error code. The other option is to run the wire directly to the outlet socket in the back and power the camera constantly when driving then manually switch screens on the Garmin when backing up. May not be worth it. Hopefully there are other install options.
Old Feb 18, 2018 | 10:18 AM
TVPostSound's Avatar
TVPostSound
I installed a BC30 to my 2595 LMT in my R56, unfortunately, the traffic stopped working.
Thought it was a bad cable, as the cable is the antenna. Garmin sent another cable, and still
no traffic, so it sits in a box.
If you have traffic, let us know if it still works.
Old Feb 18, 2018 | 11:52 AM
umberto's Avatar
umberto
hmmm ...why do you need the 50' wire? In mine, the transmitter is in the headliner just above the boot and that connect to the rear reverse light for power nearby ...a tiny hole was drilled to feed the wire for the camera and it is mounted just above the rear license plate. So wirelessly the signal is from the transmitter in the boot area to the receiver that is taped to the GPS which is the front dash area
where will your GPS be placed?
It does sync perfectly so that as soon as i turn my car on the map/GPS is running and then when i put the car into reverse it switch to the back up camera with only a one second delay
Old Feb 19, 2018 | 06:48 AM
bratling's Avatar
bratling
Super Moderator
I wouldn't consider the low position a deal-breaker. I put a backup cam at the plate in my spouse's Countryman. It's low but works fine--see my pics here:
https://www.northamericanmotoring.co...ml#post4366294
So if you can work out the rest, go for it!
Old Feb 19, 2018 | 01:23 PM
Lucas63's Avatar
Lucas63
Great idea using the switching relay and reverse light power line as a trigger.
I may try that.
TVPostSound
Nov 17, 2017 12:06 PM
Wmesq77
Jul 4, 2017 09:00 AM
TVPostSound
Jan 24, 2016 01:20 PM
boostednorm
Dec 7, 2014 07:22 AM
snid
Driver's School
May 29, 2006 08:48 PM
