R50/53 Auto air/heat
Old Oct 26, 2004 | 10:59 AM
10851CS's Avatar
10851CS
Auto air/heat
Question. Yesterday when I started my 03 MCS with auto air/heat I had nothing. Everything except the air/heat worked. Would not turn on, fan would not start, no heat, no air, no defrost, nada....
I stopped and tried to check the fuse in a parking lot but did not have a fuse puller (manuel said it was there but I could not find it). Started up to go to the parts store and buy one. When I started it up again everything worked
What's up with that? Anyone else had this type of problem??
Earl
Old Oct 26, 2004 | 11:13 AM
SwingMCS03's Avatar
SwingMCS03
I have experienced this exact same thing last winter. Once I turned off my car and restarted, everything worked just fine. I informed my dealer of the incident and ensured they documented it on my service ticket for further reference.
There are at least two other threads on this subject that I am aware of ('ACC didn't turn on' - MINI Talk). Try using the search option to find out more using 'ACC' as the seach word.
As far as I remember, no one knows what is causing this and it doesn't seem to be an on-going issue. It's just a hastle to have to worry about or deal with when it occurs.
Old Oct 26, 2004 | 11:28 AM
pc's Avatar
pc
Earl,
I've had this same problem pop up a couple of times in the last 18 months. The first time was with the AC / Heater and blower. The second time the radio and dash lights were affected also. Both times I fixed the problem by turning off the car and restarting. This seems like some sort of computer glitch. Although I'm not even sure if these items are computer controled, but as its only happend twice in the last year and a half I've not not been too concerned.
Old Oct 26, 2004 | 11:41 AM
bigpmj's Avatar
bigpmj
The fuse puller is in there..its just tough to spot. If I remember correctly, its red, and is below the fuses...u have to yank it out with your finger tips.
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
Oct 1, 2015 12:13 PM
kevinlhr310
Sep 27, 2015 02:31 PM
