Navigation & Audio Can I Add Factory Nav Unit to my R53?
Old Jan 30, 2018 | 02:18 PM
A383Wing's Avatar
A383Wing
I have a stock '04 R53 without the navigation option....large speedometer in center of dash, and smaller tachometer with computer mounted on steering column....
I know where to get the stock nav unit for center of dash cluster, and also the dual tach-speedometer pods for mounting in front of the driver.....I would just have to relocate my vacuum-boost gauge and voltmeter on either side of my tachometer now....
Can I just swap out the components to add to my car, or is there a wiring harness swap involved as well....I'm hoping it's a "plug-n-play" swap, but I'm thinking it's not that easy
If I'm ***** outtta luck, just say so and I'll ferget the whole thing
Old Jan 30, 2018 | 02:37 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Pretty sure the issue is finding somebody with special software that can reprogram your ECU to recognize the gauges from a different car.
Old Jan 30, 2018 | 04:43 PM
A383Wing's Avatar
A383Wing
Reprogramming the ECU is not a problem, I'm more concerned if it's just a direct swap of the instruments or if more items are needed, like the complete dash harness from the donor car
Old Jan 30, 2018 | 05:39 PM
Whine not Walnuts
I am not aware of any recent posts (past year) saying they pulled this off. I saw something in a FB post about people that were able to do this work but never did anymore research.
Old Jan 30, 2018 | 05:50 PM
A383Wing's Avatar
A383Wing
Yea, I did a rather extensive search here on the forum, and never found any definitive answer either
Thinking I'll just stick with my Garmin unit for now.....
Thanks guys
Old Jan 30, 2018 | 11:04 PM
rkw's Avatar
rkw
It's been done before: http://www.mini2.com/forum/3255721-post5.html (post #5). It's a lot of work with high risk for something going wrong.
That begs the question, why would you want to do it? MINI already stopped updating the maps for this ancient nav system years ago. We're talking about a navigation system with 2002 technology (as a point of reference, Apple introduced the iPhone in 2007). The map app on a cellphone works a lot better.
Old Jan 31, 2018 | 06:02 AM
chuckee98's Avatar
chuckee98
I have an '05 R53 with the factory nav unit. IMHO, it isn't worth the effort to retrofit it into an R5* that didn't come with one. The nav is archaic, and sucks, to put it politely. It is non-intuitive, and difficult to use. And this is with the latest firmware update and 2014 map update, too. For the most part, I only use it as real time map when I drive. As a point of reference, I did however, order my F56 with the factory nav, as my preference is to use a dedicated unit instead of my phone (I'm old school).
Old Jan 31, 2018 | 12:26 PM
A383Wing's Avatar
A383Wing
Ok, I didn't realize that the updates were all done.....so I'll just ferget the whole thing and move on to other items of interest.
Thanks guys
Old Jan 31, 2018 | 01:28 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
One prime example not to buy the sell up factory fancy electronic options. What keep me wide awake at night are the fancy electronic displays in the new cars. They are just cheap consumer electronic junks, and what would happen if you keep your cars for 25+ years?
Old Jan 31, 2018 | 05:01 PM
Scooter24's Avatar
Scooter24
Yeah it's been done. On here look up "navigation install hopefully a how to guide". I installed oem nav and mini connected on my 2011mcs. They also talk about the r53 and everything that needs to be bought and done on that thread.
Old Feb 1, 2018 | 12:07 AM
Paul's Avatar
Paul
Cheaper/easier to just buy the new single din Pioneer with CarPlay/AndroidAuto for $500-$600 and replace the HU.
ryanschram
Jun 13, 2010 12:21 AM
jda407
Mar 16, 2010 05:48 PM
BigPDub
Feb 20, 2009 11:53 PM
ACEkraut11
11
Nov 30, 2007 10:01 AM
j8ymp
Nov 25, 2007 11:27 AM
