R50/53 R53 hit by train
Old Jan 23, 2018 | 08:30 AM
sweible's Avatar
sweible
R53 hit by train
Hello All,
About a month ago I purchase a R53 that had been hit by a train. I know... first you are thinking TOTALED! Then.... how can you get hit by a train. it not like the hit behind tree and jumped out. yea.... long story.
Fortunately only the ladder of the train hit and it and passed through the space between the strut tower and front bumper. Only casualties were wheel, tire, strut, inner fender, hood, headlights, and hood latch.
I have everything except hood and headlight, but I think I have a lock on a hood, and I think I'm going aftermarket on head lights. Xenon's are just too pricy.
I do have a few questions I'm hoping someone can help with.
I believe this is the hood switch, where what does it connect to the body/frame?
This thing is on the side of the shifter housing. any ideas?
I believe someone tried to put an aftermarket Amp in this any ideas what I'm looking at?
Old Jan 23, 2018 | 04:25 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Pretty sure the hood switch mounts to the passenger side latch.
Also, if you have not already done so, suggest you check out the below threads. In the first, Items # 14 and 15 will give you links to look up parts and wiring schematics.
https://www.northamericanmotoring.co...ml#post4350259
https://www.northamericanmotoring.co...nce-guide.html
Old Jan 23, 2018 | 06:58 PM
sweible's Avatar
sweible
thanks for the replay. I found the wiring diagram for the hood switch and even purchase a service manual. I nothing that showed the actual placement of the switch. I also found 2 wires coming from the shifter house. I think the small ring was some type of switch, maybe for the amp that is missing from the back.
Old Jan 24, 2018 | 04:47 AM
Derek86's Avatar
Derek86
Seems like it did alright, most things that get hit by trains are not recognizable afterwards.
Reminds me of Oh Brother Where Art Thou.
Old Jan 31, 2018 | 05:16 PM
beken's Avatar
beken
That cable in your hand looks like an AUX cable for plugging in an audio device, like an iPod touch or something. Possibly, the previous owner wanted to run it to the side of the shifter console.
Old Feb 1, 2018 | 12:00 AM
Paul's Avatar
Paul
The gray and black connectors connect to the HK amp. You’re correct, looks like someone tried connecting an aftermarket amp.
The 6 and smaller 3 or 4 pin are a trunk mounted cd changer.
Check a vin decoder to see if HK was part of the build.
Old Feb 1, 2018 | 05:38 AM
JAB 67's Avatar
JAB 67
Best advice for the hood latch switch would be to find someone else who owns an R53 and ask to look under their bonnet.
Old Feb 1, 2018 | 07:47 AM
sweible's Avatar
sweible
HK was definitely part of the build. The door speaker HK grill covers were under the seat. They now have JBL grills.
F0ggy
Jun 18, 2016 05:07 PM
GPToyz
Oct 24, 2010 09:41 AM
koolmini
Mid-Atlantic
Oct 31, 2003 09:49 AM
